naturbar Posted May 9, 2009 Posted May 9, 2009 I have an 07 RSTD, we measured the crash bar diameter is it appears to just a tad under 3/4". the smallest diameter that i see for Kuryakyn Iso Pegs are 1". anyone here with a rstd have these pegs and if so what is the part # and will i need to make a shim ? Thanks in advance for any help/suggestions. Another thing, i'm buying the Hoppe Quadzilla fairing for my bike and i would like to add passing lamps (or light bar which ever you prefer) and need ideas/suggestions also.
M61A1MECH Posted May 9, 2009 Posted May 9, 2009 I used Longhorn offest cruise peg mounts P/N 7980 on my 07 Venture, they have 1" quick clamps and work just fine. Try this link http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/IMID/460
georgew48 Posted May 10, 2009 Posted May 10, 2009 That is the same ones I use on my 06 RSTD and they work great.
Jethroish Posted May 10, 2009 Posted May 10, 2009 Used the 1" clamps on my Venture. On another bike, I had th 1 1/4" clamps and 1" bar. I had some rubber gasket material so I cut it to wrap the bar with before putting the clamp on. Never had a problem with slipping. I would bet the 1" quick clamps will work just fine.
naturbar Posted May 10, 2009 Author Posted May 10, 2009 thanks guys for the help & part # - at least now i know what diameter size to purchase.
Uturn Posted May 11, 2009 Posted May 11, 2009 I needed a spacer in the Kuryakyn 1" clamp. I used a couple pieces of plastic wire ties cut about 1 inch long and slid them in, then tighten. Works great. MIKE aka Uturn
hunts4beer Posted May 11, 2009 Posted May 11, 2009 I just ordered a set of the longhorn offsets last week for my '06 RSTD. Being the thrifty shopper that I am I always try and make sure I get the best price available. My wife has a couple of other phrases she uses instead of thrifty but you get the point. Anyhow, I was able to get them delivered to my door for a hundred bucks from A & B Xtreme out of Ohio. You can contact them at 740-676-2900.
