CAN you start your 1st gen.@70 degrees temp w/out the choke when stone cold?
53 members have voted
  1. 1. CAN you start your 1st gen.@70 degrees temp w/out the choke when stone cold?
    • Yes it starts, but it idles poorly or dies
      13
    • Yes it starts and it idles slow and smooth & warms up
      33
    • No start unless I have the choke set
      6
    • No start unless I use the choke and while starting twist the throttle
      1
put 230 miles on the new spark plugs. Only #3 shows any sign of color compared to the others that are staying white as snow. Mileage...well it's nothing to rave about. Lucky if I see 36 on the hiway. I can't help but twist the throttle to WFO. Power corrupts. Also, I removed MY Jason MOD to confirm the how the plugs are "burning". Maybe w/ the MOD it will go up 2 mpg. I invented it and have had it on for almost 20 years. Now with it off...maybe it's suspect of my lesser mpgs than I remember. I may be able to dyno the bike tomorrow. If it passes my expectations. I will not do a damn thing more. Last time it had 93.2 hp. The way it runs now(rocket like- roll ons) and also sucking more fuel than I remember it should , may mean something. Oh did I mention, at far less than 1/2 throttle it's cruising @100+...?
Well try drivieing it around like an old guy!!! ( you know what I mean ) for one tank of fuel.
I know it won't be easy to do that, but, take some nice scenic back roads, enjoy the sceinery. I bet you do about 42 :hihi:
I have been doing hiway to put miles on and check the spark plugs' color. When I did go back roads...I got 41 the 1st time on the back roads 60mph avg. w/my MOD connected. Yes, I did twist it once or twice to pass the people who are afraid of the wind. I have had this bike since '89. It was never like this(super powerful, instant responsive and hard to hit 40mpg)...I am sure. Did I have a carb issue form the 1st day I owned it? If so, How did I get 93hp out of it. Wish there was another 1st gen. Venture rider close by. Who's had his as long as me. I may have been a bit over stating the throttle before. It's more like 1/4 throttle.:hihi:
Just curious Jason. I run your mod on the '83 and find it has a little more lope at idle...which I kinda like..., but I really don't notice any difference in performance or gas milage between stock and the mod. I ran the mod from Sacramento to Ft Collins[1039 miles] and got 38 mpg. Took it off before the trip home[1200 miles] and it still got 38mpg. Now here's the question. Have or has anyone connected the vacumes between 2 and 4, and 1 and 3, and if so, what was the result???
Edited by Condor
the main reason for the mod. is rather simple when comparing intake and exhaust tuning. Maybe you are aware that inline 4 cyl. bikes exhaust works best when 1 is connected to 4 and likewise 2 connected to 3 prior to dumping to the collector or muffler. This is due to the firing order. Allows even pulses. Now the same is also true for the intake. But with a V-4 the benefits vary. So lookng at the manual(there are misprints). You want 1 to 2 and 3 to 4. I do not know of anyone doing as Condor suggests. - I will say it will makes less difference on the bikes w/YICS.
- Also I had a revelation tonight. My increased performance may be simply due to my replacement BOOST Sensor. Now the lesser mileage could be a couple of things I am still investigating. Like lack of full advance , remember used-new boost snsr.
-And my lasted pain is my water pump seal. I replaced it using the old impeller,that was a Big mistake...So I replaced the seals again using a new impeller and used my Yamaha W-P special tools and I followed the book(my memory sucks) "to a T" as always. All good but on another thread I mentioned the knocking noise from the pump area. To figure out the noise, I drained the coolant,I took off the impeller cover. Started the engine and ran for a total of 20 seconds...maybe. Then not being satisfied I removed the water pump to inspect things. Not wanting to damage the oil or mech. seals I did not remove the impeller. Now tonight's ride, When hot I had a couple drops of coolant come out. Now the seal may be failed due to my short 20 seconds. Smart me> Last seal change I had installed a clear hose that fits perfectly in the weep hole using a bit of hi-temp RTV. I can see anything that comes out through this hose. I saw coolant and enough got to the exhaust pipe where the hose is just an inch away which I could smell for a split second. Which is a good warning. The hose also protects the cases and bike in general from getting messy from a bad W-P seal. My original seal lasted 65k. So you see how this is pissing me off. I am such a putz sometimes. I think the dealer loves to see me.:mo money: My baby always has something wrong. Sorry for the long windedness...
Edited by jasonm.
