MasterGuns Posted May 6, 2009 Share #1 Posted May 6, 2009 I have removed the stator cover just to reseal the two rubber gromets (stator and pickup coils) that from time to time (huh) leak. For those of you that have had to (for whatever reason) remove the stator cover, what is the best, and I do mean best, sealer to use on those pesky gromets? Any advise will be greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
jasonm. Posted May 6, 2009 Share #2 Posted May 6, 2009 (edited) Most important thing is to clean the case, wires and grommet. I found Advance Auto's Wearever brake cleaner to be very good. NON-chorinated type. So it is safe for most plastics and rubber. I did note that the smell has changed recently when using it. Meaning they may have recently reformulated it.But still works great. I will say the leak you speak of is oil coming out thru the wires. The wires are braided and this acts like a wick...drawing the oil out. Yes, a bad design. Then use Yamabond4. Which is actually a "Threebond" product. Also there is Suzuki silicone. It's used on sealing crankcase halves.It absolutely bonds to rubber grommets and o-rings. It's $20/tube. In this case, you get what you pay for. Edited May 6, 2009 by jasonm. Link to comment Share on other sites More sharing options...
MiCarl Posted May 6, 2009 Share #3 Posted May 6, 2009 Mine was also leaking because the grommet the stator wires passes through did not press tight against the cover gasket (you could see it was sub flush to the cover when installed in the slot). I put a bead of RTV on it, put the cover on just tight enough to shape the RTV and let it set over night. Then I torqued it down. That corrected my leak. Link to comment Share on other sites More sharing options...
6m459 Posted May 7, 2009 Share #4 Posted May 7, 2009 I used this when I sealed the grommets and wires that pass through the grommets and, on a different occasion, I used this when I re used the gasket around the cover perimeter. Both worked well. Hope this helps. Brian H. Link to comment Share on other sites More sharing options...
jasonm. Posted May 7, 2009 Share #5 Posted May 7, 2009 There is a sealer test that only the Yamabond/three bond can pass. Take a small bit(dime size) of any sealer. Place it on any small clean piece of metal. Let it set for the standard 24 hours. Then submerg it in motor oil or WD40 for a day or 2. You will find most all RTV's will release their grip when in WD40 in minutes and a day or so when in oil. Yamabond will not lose grip. There is one thing many do not know about Yamabond. It sets up after a few heat cycles of the engine. Thus retorquing is recommended when using it on a gasket. Link to comment Share on other sites More sharing options...
mattevans Posted May 11, 2009 Share #6 Posted May 11, 2009 YAMABOND without a doubt. This is great stuff i have used it in place of gaskets with no leak. Link to comment Share on other sites More sharing options...
Rocket Posted May 11, 2009 Share #7 Posted May 11, 2009 YAMABOND without a doubt. This is great stuff i have used it in place of gaskets with no leak. Yamabond is Three Bond 1104 in a different tube............... Link to comment Share on other sites More sharing options...
