uncledj Posted May 4, 2009 Posted May 4, 2009 I have an 87 Venture Standard that needs the aluminum engine covers polished, but I have to get the old, flaking, yellowed clearcoat off first. Once I get it off, I'll shine it up as best I can, then re-cover it with clearcoat. (spray can) Any suggestions?
MasterGuns Posted May 4, 2009 Posted May 4, 2009 I just used standard paint remover when I restored the engine cases on my 88. Once I polished them out, I used clear high heat engine paint. Turned out really nice.
cecdoo Posted May 4, 2009 Posted May 4, 2009 NAPA gasket remover takes it rite off, mask anything you dont want stripped with tape and alum foil. Craig
petekadish Posted May 4, 2009 Posted May 4, 2009 I purchased an old Royal which was caught in a garage fire years ago. The heat kinda baked the clear-coat on the front end of the bike and gave it sort of a brass look. To remove the old clear-coat I used a combination of three things. 3M Scotchbrite Pads, Carb or brake cleaner and some Flitz metal polish. Oh yea ..., lots of elbow grease, rags, a long winter and patience Be aware that carb & brake cleaner is pretty caustic stuff. It's hard on skin and will mess-up a lot of things you wished that it didn't get on. I did all the work by hand without removing the parts from the bike,and it was a pretty tedious process. I'm sure that if the parts were removed, someone who had the proper equipment could do it much quicker and easier. Attached are a few pictures of what I had to work with. Good luck! Pete.
uncledj Posted May 4, 2009 Author Posted May 4, 2009 Looks like the paint or gasket remover is the ticket. I was concerned that it may affect the aluminum, but since y'all have had good luck with it, my fears have subsided. Thanks.
Monty Posted May 4, 2009 Posted May 4, 2009 I hear a lot of people say they use aircraft stripper. Wal-Mart carries it. Comes highly recommended for this application.
petekadish Posted May 4, 2009 Posted May 4, 2009 I believe that President Clinton had an Aircraft Stripper on Air-force One, but President Bush decided that she wasn't appropriate. I know that my wife wouldn't approve. So, you might want to just listen to the radio while you work on it to be safe. Pete.
CrazyHorse Posted May 4, 2009 Posted May 4, 2009 (edited) Aircraft Stripper at auto part stores melts it right off be careful with getting it on your s hands. The store clear coat wont last they use a higher level coating. I powedered coated my covers black. Edited May 4, 2009 by CrazyHorse
