I would look at fuel delivery carbs,diaphrams,floats etc or possibly test the boost sensor like squeeze says. Are all the boots secured top and bottom to the carburators?
This has been a good one boys and maybe this winter I will remove the carbs and go through them. Right now it is running fine I made a trip this summer to North Carolina and back and ran fine. I am not a speed demon anyway but am the type of person that if I know something is not right it bugs the hell out of me. I have since bought a K1200lt BMW and have been putting some miles on it so can now work on the Yamaha. I might bring it to the maintenance day at Free Bird's place in June.
You guys are great
Thanks,
Curtis
  • 5 years later...
My '92 maybe has the same problem. If I twist the throttle past a certain point (80%?) it acts like it has dropped a cylinder! Otherwise it runs, starts and drives great. It will red line if I ease up to it. I have a fuel smell that I tracked to a leaky float bowl. PO changed the ignition box and I synch'd the carbs.
Did you solve your problem? Inquiring minds want to know . . .
Edit: 13 Jul 2015
I reconnected the original ignition box and sprayed carb cleaner everywhere while the air box was off.
Now the Blue Bomber runs like a raped ape! WOT in any gear and easily red lines in lower gears.
I'm thinking the carb cleaner knocked loose debris in one of the carb jets.
Lovin' my Gen I
GaryZ
Edited by GaryZ
