CrazyHorse Posted November 3, 2009 #26 Posted November 3, 2009 I would look at fuel delivery carbs,diaphrams,floats etc or possibly test the boost sensor like squeeze says. Are all the boots secured top and bottom to the carburators?
ctraylor Posted November 3, 2009 Author #27 Posted November 3, 2009 This has been a good one boys and maybe this winter I will remove the carbs and go through them. Right now it is running fine I made a trip this summer to North Carolina and back and ran fine. I am not a speed demon anyway but am the type of person that if I know something is not right it bugs the hell out of me. I have since bought a K1200lt BMW and have been putting some miles on it so can now work on the Yamaha. I might bring it to the maintenance day at Free Bird's place in June. You guys are great Thanks, Curtis
GaryZ Posted July 8, 2015 #28 Posted July 8, 2015 (edited) My '92 maybe has the same problem. If I twist the throttle past a certain point (80%?) it acts like it has dropped a cylinder! Otherwise it runs, starts and drives great. It will red line if I ease up to it. I have a fuel smell that I tracked to a leaky float bowl. PO changed the ignition box and I synch'd the carbs. Did you solve your problem? Inquiring minds want to know . . . Edit: 13 Jul 2015 I reconnected the original ignition box and sprayed carb cleaner everywhere while the air box was off. Now the Blue Bomber runs like a raped ape! WOT in any gear and easily red lines in lower gears. I'm thinking the carb cleaner knocked loose debris in one of the carb jets. Lovin' my Gen I GaryZ Edited July 13, 2015 by GaryZ
Beau-Kat Posted July 13, 2015 #29 Posted July 13, 2015 Oh well, I see that this post was started several years ago and that ctraylor has an expired membership. I was gonna suggest he read through this thread of my troubles. http://www.venturerider.org/forum/showthread.php?101878-Engine-won-t-rev-past-about-4600rom
