  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
don, I would be interested in buying the 89 from you. are you going to be around this week so I can come down from Buffalo? thanks, Jim
Hey ,how come you don't ride with us on weekends?? This is really funny, because the part Don is getting for the dash is coming from here!
Make sure you make the Pioneer Motorsports ride for Breast Cancer on the 16th. We're right around the cornewr and will have coffee for Ventureriders in the AM...
That really is a nice lookin warshing machine...............
Boomer......running fer cover now.:rotfl:[/QUOT
Boomer......wasting time trying to outrun a 1st GEN:whistling::rasberry:
Like to see how that thing is set up.
i,m just too busy, i,ll try to make it on the 16th if I can pick up the 89 by then
  • 2 weeks later...
Jason,
Yes, it has VMAX cams and valve springs. I have not ridden it hard and certainly nowhere near the 9,000 RPM range. In fact, the only time I rode it was when the day that I bought it and rode it home. Once it was sold and I had a deposit on it, I didn't feel that I had the right to ride it any longer.
Now from what I can tell, and I don't know much about the VBoost system, there is no servo on it so the VBoost is open all the time. I talked to my good friend Rick Butler in Texas about this. Rick built a Venture SS several years ago and told me that he did not use the servo and the VBoost was active all the time on his also. I then did some research online and found that even a lot fo VMAX riders remove or disable the servo so that the VBoost is active at all times. That appears to be the case with this one from what I can tell. It also explains why is has such a lope at idle. It sure sounds good though.
I tried to take some pictures but it is kind of hard to get them. Here they are though.
Edited by Freebird
Oh...and the '89 will be headed to it's new home in Buffalo, NY later today. I wish I could have put a few miles on it but it just sold before I could do so. It really is a sweet running bike.
Thanks for the pics Don. Interesting to note about leaving it active all the time. I had been thinking about how to control it. Neat setup on the PCV system. Makes it easier to set mine up.
Other things I noticed are no carb drain tubes and the open tubes on top of the carbs. Is this a trait on the later carbs?
Those Filters as well as the Canister are Part of the Dyna Stage7 Kit for the Vmax. There's a Engine Breather Hose feeding back to a special Oil Fill Plug from the Canister.
I have no idea about the carb drain tubes. It's been a long time since I owned a first gen and don't remember if my '88 had those or not.
GOT HOME ABOUT 5:30, MET SOME FRIENDS IN ERIE AND AFTER LUNCH HEADED UP TO BUFFALO BY WAY OF ELLICOTVILLE. BIKE RAN SWEET, THANKS FOR EVERYTHING DON.HOPE TO MAKE IT TO MAINTENANCE DAY.
:Venture::fireman: JIM
Good deal. Glad you had a nice ride home and that the bike ran good. I think it will be a good bike for you for a LONG time. Sure sounded good as you were heading down the driveway. :)
Jason,
..... I talked to my good friend Rick Butler in Texas about this. Rick built a Venture SS several years ago and told me that he did not use the servo and the VBoost was active all the time on his also. I then did some research online and found that even a lot fo VMAX riders remove or disable the servo so that the VBoost is active at all times. That appears to be the case with this one from what I can tell. It also explains why is has such a lope at idle. It sure sounds good though.
On my 98 Max, I unhooked the electrical connector to allow the servo to be on VBoost all the time. Didn't really see what the big deal was, so I hooked it back up to normal. My bike is all stock. I guess you gotta do the stage kits for it to make a difference.
Maybe I'm just an old man and just like the good old "feel" of the servo opening and the boost kicking in in the midrange. Kinda like the power band on my old 250 Elsinore.
Whatever floats yer boat...
