frankc Posted April 30, 2009 #1 Posted April 30, 2009 Now i know someone posted this before but, you know how it works, i can never find things when i need them so please bear with me. Does anyone know who makes an air pump with a gauge to be used on the shocks. I need it to be small enough to carry with me. i would like to try different pressures while i'm on the road to find the best combination. Thanks everyone and have a safe summer
rod Posted April 30, 2009 #2 Posted April 30, 2009 Progressive has them, you can find them at HD dealers around here. Good luck Rod
eagleeye Posted April 30, 2009 #3 Posted April 30, 2009 I think it would be hard to beat the Harley Davidson pump. Steve
Venturous Randy Posted April 30, 2009 #4 Posted April 30, 2009 In the 99,000 miles I have put on my 83 Std 1st gen, this is what has worked best for me. Harbor Freight has a small compressor with a gage that cost about $8. I have found that I can attach it and when I turn it on that it will show pressure on the hose and when it gets to a certain point it will off seat the valve core in the valve stem, letting in air. I know this because when I turn off the compressor, the gage goes to zero and air does not leak from the shock. I can also use the gage as a reference because whatever the gage reads when pumping will be the same as my digital air gage reading. On my digital air gage, I put a slightly thicker o-ring on it. This causes me to have to push slightly harder to get a reading, but it is vertually "a no air loss" reading. I know there will be some saying you can not use an electric pump on your shocks, but I have done it for about 13 years and almost 100,000 miles and have never had a problem. The pump from HF has a gage and also has an on/off switch in the wire. For me to go from 40 to 65psi will take several seconds and is real easy to control exactly how much air I put in the shock. I even use this on my front shock and not exceed 12psi. RandyA
GunnyButch Posted April 30, 2009 #5 Posted April 30, 2009 Here's a link to one that I like, 0-60psi lets you adjust tires and suspension. I wouldn't recommend trying to pump a tire up with this but the bleeder valve lets you adjust to exactly the pressure you want with no loss of pressure when you disconnect. http://www.jpcycles.com/Search/ProductDetail?sku=910-177&N=0&Ne=0&Ntk=All&Ntt=suspension%20pumps&Ns=DefaultSort&results=10&No=
Sideoftheroad Posted April 30, 2009 #6 Posted April 30, 2009 The one from Progressive and HD are one in the same. If you want the one from Progressive, find the one w/ their logo as the one with the HD logo is more expensive.
okscott Posted April 30, 2009 #7 Posted April 30, 2009 http://www.cruisercustomizing.com/detail.cfm?Category_ID=96&manufacturer_ID=39&product_ID=5364&sblid_name=Progressive_Suspension_Mini_Gauge_Pump&model_id=41 $44.96 plus shipping
