RedRider Posted April 29, 2009 #1 Posted April 29, 2009 As some of you may have recalled, I had a tire blow last year while running through West, by God, Virginia. It was a Dunlop D404 that had been put on a couple of months previously. I was beating myself up for neglecting to check my tire pressure and was sure that was what killed it with 5581 miles on it. For a lot of expense (towing, hotel stay, tire, install, etc.) I was able to get another D404 installed so I could get home. That was the only tire available at the time. Well - IT ALMOST HAPPENED AGAIN! I was recently on a 4000 miles run around and was meticulously checking the tire pressure. It never varied from the original 40 lbs. However, as I was checking the tire pressure after getting gas, I noticed the tire wear was extreme. It was already down to, or below, the wear bars in the center of the tire. Thank goodness it was so windy that I wasn't running on the center of the tire. Since I was about half way across South Dakota and had a good 600 miles (most to be at night) to get home, I thought prudence would be the better part of valor. I pulled into a rest area and got on the phone and found a dealer in NorthWest Iowa with a - D404 tire!!! I had to get home and wanted to get there in one piece. When I punched the dealer address into my GPS, I noticed it would be 6:30 (they close at 6:00) before I got there. I pulled off the next exit to see if I could find a dealer any closer. Luck had me pull into Chamberlain, SD. I asked for a phone book but there were no M'cycle dealers listed. The clerk mentioned there was a Honda dealer the next exit down, I called and they had - an Elite 3 in the appropriate size. Apparently, that is what the Wings use. Showed up, they had me drive right into the shop, and the technician and I got to work. I took off the saddlebags, dropped the pipe, and took off the brake caliper. The tech started on the axle. We jacked it up with a standard floor jack balancing it against the kickstand. While the tech removed the dead D404 and installed the E3, he told me where the Moly60 was and I greased the splines. We reinstalled and I paid the standard bill (list price on the tire, but no complaints here). Slipped the tech a twenty on the way out for getting right on it and for letting me help. 45 minutes in and out with a new E3. OK, bottom line. I got lucky this time. The D404 was not designed for this bike - regardless what the Owners Manual says. The D404 that blew in WV had 5581 miles on it. I now firmly believe the WV tire died a natural death, not from neglect (although, I neglected to inspect for tire wear). This tire, when removed, had 4311 miles on it. Would it have made it another 600 miles? Maybe. But there will never be another D404 on my bike - if I can avoid it. Just a note on the E3. I felt the tire was not quite as smooth on groved pavement as the D404. Almost like it was a 'harder' tire. However, it might be that the tech did not balance the tire. I was in a rush and we both just forgot. I'll throw in some Dynabeads this weekend and that might help. It is a very small price to pay if I can actually make a trip and return safely with the same tires on the bike. The Darksiders almost had me coming over after this. We will see how the E3 works out. Hopefully, I will be able wear it out this year - by riding a lot!! RR
Monty Posted April 29, 2009 #2 Posted April 29, 2009 My E3 is working great. 1500 miles so far, so it's still early. The little rubber "tits" are still on it, though.
GeorgeS Posted April 29, 2009 #3 Posted April 29, 2009 I cross cut a D 404 and an Elite II ( previous model to E-3 ) 404 caseing is 1/4 inch thick, E-II caseing is 1/2 inch thick. I assume the E-3 is the same thickness. That E-II. I took off 2 years ago, had about 22K on it.
Wanderer Posted April 29, 2009 #4 Posted April 29, 2009 My sentiments exactly on the D404. Never again. Having said that - guess what's on the new one I just bought? Yep
pegscraper Posted April 29, 2009 #5 Posted April 29, 2009 I don't understand it. The one time I put D404s on my bike, I got 16,000 miles out of them, both front and rear. I didn't have any complaints about them in general. But I do the CT boogie now anyway.
GeorgeS Posted April 29, 2009 #6 Posted April 29, 2009 Thats a good point !! concerning D-404 milage. Its almost as if they are makeing them in two places, one good and one bad !! Or they have changed the rubber compound, and no way to tell the difference. I feel they are just fine for a small run around town bike, but not a heavy toureing bike. The E-3 is made for the Gold Wing!! Nuff Said
flb_78 Posted April 29, 2009 #7 Posted April 29, 2009 I put 404's on my Roadstar and only did about 4000 miles before the rear was bald. Front only went about 8000.
BIG TOM Posted April 30, 2009 #8 Posted April 30, 2009 I'm confused...I run 404's...my last set I got 11,000 miles out of them. just replaced them with new 404's two weeks ago...the front still looked good..but, I decided to replace it any way...most of my day rides are in the 200 mile range..might that have something to do with it...I like the way they handle...
RedRider Posted April 30, 2009 Author #9 Posted April 30, 2009 Big Tom, I also liked the way they handle. But I take too many long trips to replace them every time. RR
Mariner Fan Posted April 30, 2009 #10 Posted April 30, 2009 I didn't have any troubles with my 404's. I'm wondering if the replacement tires aren't as good as the one's put on the bikes when you buy them. I just put an Elite 3 on the back and I like it alot.
Monty Posted April 30, 2009 #11 Posted April 30, 2009 I have noticed lately that the 404's do not last near as long as they used to, so I switched to E3s.
PastorPaul Posted April 30, 2009 #12 Posted April 30, 2009 I have a set of 404's on my 02 rsv. they ahve almost 10,000 miles on them and the rear has almost half it tread depth left. Front still looks like new. But then again I baby my bike as it has to last me a long time. My 83 venture had 274,000 on it when it died and all I ever did was routine maint.
Sylvester Posted April 30, 2009 #13 Posted April 30, 2009 I never had luck with Dunlops on my 2000 Ultra Classic, but on my RSMV I love them. The Metzzler ME 880, that I previously had, really sucked.
papa smurf Posted April 30, 2009 #14 Posted April 30, 2009 wow. this makes me think that it's gotta be about riding style. there are so many divergent opinions. but let me just add this. I check my tire pressure obsessively. its the number one cause of failure. do it.. it only takes a few minutes. ride safe yall
kj4v Posted April 30, 2009 #15 Posted April 30, 2009 11,500 on my 1st set and only 5000 miles on my 2nd set I couldn't believe the differance on the same tire. I was lucky someone noticed it and brought it to my attention. Now on the other side, Tom Moyer had a new E3 installed and it blew out at 75 miles and just after he had checked his air pressure. I just don't know if any tire cane be trusted any more....Ken
BradT Posted April 30, 2009 #16 Posted April 30, 2009 I get about 12,000 miles on the rear and pulled them off with about 1/16-1/8" left to te wear bars and that was the same for two tires. The front has have gone 23,000 miles and needs to be replaced. I do a lot of two up riding and pull a piggy backer. I will get another set of D404 WWW Brad
juggler Posted April 30, 2009 #17 Posted April 30, 2009 Careful what say. Like others have mentioned I also get 10 - 12 thousand miles out of my D404's and I've never been below the wear indicators at that point, just close enough for me to say it's time to change. I did destroy the last one in a big nasty pothole, but that would have killed any tire. Even then that tire had 12k on it before I ripped a chuck out of the side wall in that pothole. I have bought two sets of D404 WWW replacements since I've had this bike and I plan to keep buying them. I ride one up for my daily commute and two up the rest of the time and last year I started pulling a trailer. There is a lot of weight on that rear tire and it holds up fine for me.
saddlebum Posted April 30, 2009 #18 Posted April 30, 2009 I just found out today that dunlop due to popular demand has put the elite II back in production and that is what is going back on my bike . I was really satisfied with my first set.
az1103 Posted April 30, 2009 #19 Posted April 30, 2009 12000 + and still going...... Have no complaints.....
royalstarjac Posted April 30, 2009 #20 Posted April 30, 2009 The last D404 I had on the rear was showing cord at 2,500 miles. Never again.-Jack
1sttenor Posted April 30, 2009 #21 Posted April 30, 2009 Question??? What kind of terrain are you guys in when you get over 11K? I typically ride like your grandma, but only got 6-8K out of mine? The terrain in my area is hilly and twisty though.
RandyR Posted April 30, 2009 #22 Posted April 30, 2009 this is really strange. some D404s getting very low mileage, less than 4,000 miles and others getting well over 10,000 miles. is this an inconsistent quality problem or the way they are used?
RedRider Posted April 30, 2009 Author #23 Posted April 30, 2009 My travel was 90% slab at 75 to 80 MPH. The other 10% are nice twisty roads at 30 to 50 MPH. Nothing extreme. Riding was 1up with full bags. RR
oldandcrotchety Posted April 30, 2009 #24 Posted April 30, 2009 saddlebum said: I just found out today that dunlop due to popular demand has put the elite II back in production and that is what is going back on my bike . I was really satisfied with my first set. Great news! My all time favorite tire. Wears like iron.
Guest Saddletramp Posted April 30, 2009 #25 Posted April 30, 2009 Inflation and riding style have a lot to do with tire wear. However tires are like a piece of fruit, you can't tell what you've got without cutting it open. I have ran 404's, me880 and stones. I've no negative comments about either the Metzlers or Dunlops, but the stones never lasted well. I have always ran my tires at the tire manufacturers max pressure as displayed on the sidewall not the decal on the bike itself.
