algie1100 Posted April 22, 2009 #1 Posted April 22, 2009 One of my speakers was shot on my 90, so I replaced them with a new set. I got everything back together and the radio was working great. A few days later I went for a several hour ride and again the radio was working great. But after I pulled the bike into the garage the radio just stopped working along with the cassette and CB. I checked all the fuses under the battery cover and they were all good. Is there a hidden fuse somewhere else that I should check? Or is there a wire that might have come loose? Thanks, Al
Marcarl Posted April 22, 2009 #2 Posted April 22, 2009 Take out the left front signal light and you'll find 2 inline fuses that supply the radio etc. Power goes from there to the radio\tape player, and then across to the CB. One fuse is for constant power, the other is for switched power.
CrazyHorse Posted April 22, 2009 #3 Posted April 22, 2009 Are the radio connections ok when you lay the radio in the craddle? Mine would somtimes go out because the radio connectors were not connecting properly
Condor Posted April 22, 2009 #4 Posted April 22, 2009 Check your intercom button and the CB squelch.. ??
mbrood Posted April 22, 2009 #5 Posted April 22, 2009 Now what moronic engineer decided that the fuses for the radio would be "rightly" located behing the left front turn signal??? Some things on these bikes make me really scratch my head. Glass fuses over the battery but a spade fuse block located in front of the battery...? I mean... come on... pick one type...
calperin Posted April 22, 2009 #6 Posted April 22, 2009 Hey, what's wrong with the engineers???? This is a marketing strategy!!! How we going to get the people captive on maintenaince if everybody knows how to fix the problems???? :mo money:
algie1100 Posted April 22, 2009 Author #7 Posted April 22, 2009 Take out the left front signal light and you'll find 2 inline fuses that supply the radio etc. Power goes from there to the radio\tape player, and then across to the CB. One fuse is for constant power, the other is for switched power. I'm guessing this is the problem. I guess I get to tear it apart again.
Marcarl Posted April 23, 2009 #8 Posted April 23, 2009 I'm guessing this is the problem. I guess I get to tear it apart again. Not a big issue,, 5 minute job.
