SteveP Posted August 15, 2007 #1 Posted August 15, 2007 Just received the Kuryakyn Shift Peg covers and am having a bear of a time trying to remove the OEM rubber covers from the shifter. On my other bikes I was able to muscle it off over the end of the shift peg without cutting (or otherwise damaging) the OEM rubber. Anybody have the Kury shift peg covers installed? How did you get the OEM rubber off? Did you have to cut them off? I don't want to reinvent the wheel here; I'm sure somebody out there knows the trick and will share it here. Thanks!
pegscraper Posted August 15, 2007 #2 Posted August 15, 2007 I haven't tried this, although I have felt the firmness of the rubber covers. I've considered the Kuryakyn covers myself. You might try a heat gun to soften the thing, or try prying it with a screwdriver and squirting some soapy water underneath it, or both. Just some guesses for you. Shoot, try a gear puller.
Moakster Posted August 15, 2007 #3 Posted August 15, 2007 Are you sure they don't just fit over the stock rubber on the shifter and tighten with a set screw. The Yamaha brand goes on that way. Figured the others would too. That leaves you with the stock if you ever change your mind. Moakster
Moakster Posted August 15, 2007 #4 Posted August 15, 2007 The Kuryakyn shift peg according to their web site is designed to encapsulate the existing peg. There are two different styles. KY-8851 is the slip over the existing peg KY-4034 is a clam shell version Moakster
Little Bob Posted August 15, 2007 #5 Posted August 15, 2007 I have them on my 07. Take a small flat blade screwdriver and work ththe rubber over the end of it. You should be able pull them off after that. A little prying from the screwdriver and you will be good to go.
Eck Posted August 15, 2007 #6 Posted August 15, 2007 Using one hand, work the screw driver all the way around it in cirlces breaking it loose from the steel rod it is on, and at the same time pull on it towards you with the other hand..It will come off, but is a slow process.. NOTE: The Kuryakyn slip-on cover DOES NOT go OVER the OME rubber cover
SteveP Posted August 15, 2007 Author #7 Posted August 15, 2007 It looks like a little prying and a lot of patience will do the trick. I'll be in the garage after dinner tonight! Thanks for all the replies. I'll post my results this evening.
Moakster Posted August 15, 2007 #8 Posted August 15, 2007 Kuryakyn Shift Peg Cover http://www.cruisercustomizing.com/images/ky-8851_200.jpg http://www.cruisercustomizing.com/graphics/spacer.gif http://www.cruisercustomizing.com/graphics/zoom.gif Buy Now from CruiserCustomizing Part Number: KY-8851 MSRP: $16.95 Price: $15.26 http://www.cruisercustomizing.com/graphics/onsale.gif Hurry, offer ends soon Add a free key chain to your order. Why buy from CruiserCustomizing? - Satisfaction Guarantee - No Hassle Returns - Free Shipping Specials - Exceptional Customer Service - Thousands of Happy Customers http://images.scanalert.com/meter/www.cruisercustomizing.com/12.gif This hot looking cover adds a custom touch in minutes. Designed to encapsulate the existing peg. Installation couldn't get much easier. Rich chrome and black rubber finish. Our chrome shift peg cover works great on a wide variety of bikes. Secured with rubber sleeve on virtually any shift peg. Covers shift pegs approximately 2-9/16" and 9/16" in diameter. Note: works great on most Kawasaki, Suzuki and Yamaha cruisers!
seforeman Posted August 15, 2007 #9 Posted August 15, 2007 I had the same problem - I just cut them off. Was easier. They say to use "krazy glue" to hold them in place - any of you use that? I was thinking of using the same stuff they sent with the grips? Thoughts? Stu
Moakster Posted August 15, 2007 #10 Posted August 15, 2007 Oh Well, I'm out of this discussion. Gook Luck with the pegs steveP they look great on the Kuryakyn web site. Moakster
Eck Posted August 15, 2007 #11 Posted August 15, 2007 They say to use "krazy glue" to hold them in place - any of you use that? I was thinking of using the same stuff they sent with the grips? Thoughts? Stu Stu, I do not use super glue. I highly reccomend using black RTV adhesvie... You can always "remove" the foot peg cover if you want to, with out damaging the peg cover or the bike in any way. I use it all the time on most things (like your grips), and it only costs a buck at the dollar store.. It can be used to install mood lights also. I find th edouble back tape has become soft due ot the excessive heat (104 degrees down here) and a couple of my mood lights came loose. SO I used the RTV adhesvie, and it seems to be working just fine. The RTV adhesive can also be removed with WD-40, leaving no marks......or damage to painted surfaces as super glue would.. Just my 2 cents.....
whozleft Posted August 15, 2007 #12 Posted August 15, 2007 Eck's on here talking about "mood lights". What's next, a pic of Eck's bike with a mirrored ball hanging under the trunk? What kind of mood would that put ya all in? You guys all have a great day.
Eck Posted August 15, 2007 #13 Posted August 15, 2007 Eck's on here talking about "mood lights". What's next, a pic of Eck's bike with a mirrored ball hanging under the trunk? What kind of mood would that put ya all in? You guys all have a great day. SO.........ah........thanks for the idea... a mirrored ball hanging under the trunk huh?...hum...???
SteveP Posted August 15, 2007 Author #14 Posted August 15, 2007 .... Designed to encapsulate the existing peg. Installation couldn't get much easier. Rich chrome and black rubber finish.... Moakster: The instructions inside the packaging say that the Kury will fit over "some stock shifters." And goes on to say if it doesn't push over, then you must remove the OEM rubber, apply some black electrical tape to the shifter to build it up a bit, then slide on the Kury cover. Trust me, on the RSV, the Kury will not fit over the shifter peg with the OEM rubber still on.
Moakster Posted August 15, 2007 #15 Posted August 15, 2007 Works for me. I guess you can't believe what you read on the web sites.
Jerry W Posted August 15, 2007 #16 Posted August 15, 2007 I have those shifter peg covers on my bike, you can remove the stock rubber like Bob and Eck said. That is how I got mine off. The put on a few wraps of electrical tape and I used a little silicone adhesive to hold them in place. There is a small allen head on the new cover that you need to position out of the way and snug down also. Hope this helps
SteveP Posted August 16, 2007 Author #17 Posted August 16, 2007 Thanks to all for the input & suggestions. I was able to get the OEM rubber off the shifter pegs using a small screwdriver to pry/stretch while rotating and pulling. I need to pick up some RTV (to add to the numerous tubes around my garage that I can never seem to find after the first time I use them:confused24:). Tomorrow, I'll wrap some electrical tape to build up the shift peg and seal everything up with some RTV sealant and snug up the set screw. Thanks, again.
