Guest Swifty Posted April 19, 2009 #1 Posted April 19, 2009 First time out this year...speedo works fine, but odometer doesn't. What's going on?
bongobobny Posted April 19, 2009 #2 Posted April 19, 2009 Well, the faster you go, the shorter the distance, so I guess that explains it...
Marcarl Posted April 19, 2009 #3 Posted April 19, 2009 I hear that the older you get the less a speedo works,,, but the odometer still clicks on,, maybe you are in need of glasses. Maybe you could ASK ECK, he has all the answers. Try pushing the reset button on the tripometer, could be that it's not centered properly and got things tied up. It does happen.
Guest Swifty Posted April 20, 2009 #4 Posted April 20, 2009 Marcarl said: Try pushing the reset button on the tripometer, could be that it's not centered properly and got things tied up. It does happen. 3x no difference....bump.
Guest Swifty Posted April 20, 2009 #5 Posted April 20, 2009 I NEED A SPEEDO DASH ASSEMBLY....anyone parting this out? Send me a PM please.
Condor Posted April 20, 2009 #6 Posted April 20, 2009 There's a couple of 1300 dashes on Ebay right now. Although I can't remember seeing one in KM's...
Guest Swifty Posted April 22, 2009 #7 Posted April 22, 2009 got it covered locally, and thinking of changing the Browner's name to Benjamin Button as a result. For those serious responses, thanks, and for those that were not so serious....
Marcarl Posted April 22, 2009 #8 Posted April 22, 2009 Swifty said: got it covered locally, and thinking of changing the Browner's name to Benjamin Button as a result. For those serious responses, thanks, and for those that were not so serious.... Always glad to help,, but when it comes to older speedos I thinking there's very little that can be done. Sorry to deflate your bubble,,,but that's life and you might as well get used to it.
Rocket Posted April 22, 2009 #9 Posted April 22, 2009 Marcarl said: I hear that the older you get the less a speedo works. Swifty in a speedo........... Perish the thought........ Now that he has sourced one, I couldn't resist...........
