Craig Gulley Posted April 19, 2009 #1 Posted April 19, 2009 (edited) Found this website and they claim to have a fix for sightglass http://www.newrivercyclesalvage.com/%20glass.html Edited April 19, 2009 by Craig Gulley
Craig Gulley Posted April 19, 2009 Author #2 Posted April 19, 2009 Seems as though my url is not working
Snaggletooth Posted April 19, 2009 #3 Posted April 19, 2009 Try this one. http://www.newrivercyclesalvage.com/sight%20glass.html
Craig Gulley Posted April 19, 2009 Author #4 Posted April 19, 2009 Why wont my link work? Your link was good
Snaggletooth Posted April 19, 2009 #5 Posted April 19, 2009 I'd be willing to give that a shot. I've been buffing old sights down with very fine wet & dry paper then give them a coat of super glue and let it dry. An improvement..... but not like new.
Captainkirk Posted April 19, 2009 #7 Posted April 19, 2009 Let me know if it works, Craig, and then we'll BOTH have good master cylinders! (You first, though!)
Craig Gulley Posted April 19, 2009 Author #8 Posted April 19, 2009 I am still leaning towards the idea of backing the hole with a pc of plastic then filling hole with epoxy and epoxy a dime or nickel over it. I dont need a sight glass. I dont have a problem taking out 2 screws to check if need be.I have to spend my money on new Diaphrams and things that are more important
Craig Gulley Posted April 23, 2009 Author #9 Posted April 23, 2009 Finally got around to seeing if this $300.00 84 Royale has a clutch or not. Both sightglass on clutch and brake were broke through and had no fluid in them. Rather than forking over $50.00 or more for new used masters I took cold weld epoxy,backed the inside of hole with some tape and filled it up and ran a little on outside edge and clamped a nickel over the epoxy hole. Gravity bled the clutch,I have a lever and the clutch seems to work,on the center stand.No leaks.
Snaggletooth Posted April 23, 2009 #10 Posted April 23, 2009 You could have at least used a Bufflao Head!
Craig Gulley Posted April 23, 2009 Author #11 Posted April 23, 2009 Yeah I know, but I had one in my pocket at the time. Cleaned it off with some acetone and stuck it on.
