Hi together,
i just bought an 85 XVZ12T, and have an E5 error. when i turn turn the key in the CLASS position the display switch from show all to E5 and back.when i turn on key i hear just a click from the rear pump sektion .
Today i remove the class and do the E4 error fix like i saw it here but it doesnt help, does anybody have an idea what E5 means i searched the site but found nothing about E5.
would be great if you can help me out
sincerly
harry
E 5 is Control Unit Has Trouble
Make sure battery is up good.
It doesn't give much info on this one. Book says
E 5
The error sign always appears with the
main switch turned to ACC
YES The Controller is Abnormal
NO In good Condition
Hey Harry,
I turn a pretty fair wrench but when it comes to electric problems I'm all thumbs. It took me three times to solve my E5 error on my CLASS System. Take another shot at it, you might get lucky.:080402gudl_prv:
Earl
Simple question. I thought my CLASS was broken, because I couldn't see anything in the screen. I just discovered that it does work when the key is on Accesory. Is that normal?
good morning guys, thank u for the quick answers.
i will check the voltage tomorrow and see how strong it is.
if it is to low i will try to take another battery with jumper cables to my bike and see what happens.
i will also check the front connectors cause the monitor warning light says an back and brakelightfailure but all bulbs are ok and working.
one other thing: i work at an yamaha dealer ship and can can find out if parts are still avaible if somebody need to know. i can also download the full spareparts catalogs if somebody need them too.:innocent-emoticon:
sincerly
harry
