I won this used License Plate Holder with Lights (Item# 170318869042) and I am wondering if there is an LED lamp available bright enough for the application (68230-97b).
What would be the color of the wire I should be looking for inside the license plate holder area to connect to the assembly? Is this a straight bolt on? Tips please.
Edited by N3FOL
I couldnt open your link so I cant see what ya won, I put an led lisc. plate holder on my bike. Behind the plate you tie into the Blue wire for running lites and yellow wire for brake lite. Mine was a very easy swap, I just slid the connectors apart put new wire in female connector and slid male in to clamp new wire in, no splices. Craig
Not sure why the link that I add is no longer there. I just completed the transaction and paid for it today. Perhaps you can search eBay via the Item #.
It is the Harley Touring Light Chrome Rear Auxilliary Light
Hello Craig. Are the wires located right on the plate holder? Have not really looked until I remove the plate holder on my '07.
Ok thats not the one I used, but have you checked the second gen tech section, I think there is a writeup on installing the Harley lites. If you look at your rear fender from the side, behind the Lic plate you will see a chrome bump out-all the wires are in there, tightly coiled up, you just need to carefully separate them and work on one at a time, guess you are gonna need wire colors for turn signals as well. Craig
Craig,
I just intend to use these lights are Run and Brake Lights only. From your reply, I will just look for the Blue and Yellow wire on the RSV...but I need to verify which color wire is the Run and Brake wires on the Harley 68230-97b. Thank You.
Does anyone know what kind of LED lamp I should order to replace the bulbs on the Harley Aux Light part # 68230-97B? I think the assembly takes an 1157 type bulb...I've seen a few on the CustomDynamics website, but still unsure. :puzzled:
Thanks KiteSquid. I will have to triple check the bulb that came with the assembly. The last time I looked, it is an 1157 bulb with contacts on the same plane at 180° of each other...Not Offset and the bottom of the bulb has 2 contacts. This tells me that it is a dual 1157. Most places say that an 1157 bulb will have an offset contact and has two point of contact on the bottom. I think it has an older type 1157 bulb.
My apologies...I guess from the last time I checked the old bulb, it looked like an 1157 with no Offset on the side contacts. I was in a hurry to get to work. :innocent:
Last night, I just confirmed that it is an 1157 with an Offsetted side contact. I ordered the 1.80" LED clusters that should fit the housing. This afternoon, I may go ahead and install the Aux Light/Tag holder.
