Monty Posted April 13, 2009 #1 Posted April 13, 2009 I have an '83 standard. Lately, I have noticed alot of bouncing in the front end. I've only had the bike for around a month, and I didn't notice it at first. I do know that one fork seal is leaking some. I am running 14 pounds of air in the forks. It also takes a second or two to raise up after I lift the bike off of the sidestand. Fork rebuild is not an option at the moment, and I was wondering if I just drain the fork oil and change it out, if that will help for a while. Could the bouncing be from the forks being low on oil?
Yammer Dan Posted April 13, 2009 #2 Posted April 13, 2009 Too much air. You can try making sure there is enough oil in there. It is probally low or dry. You need Progressive Springs.
Monty Posted April 13, 2009 Author #3 Posted April 13, 2009 Thanks. I had let some air out before, and that's when the seal started leaking...was dry before that. The manual calls for 12-18 PSI, so I had set it to 14. I will get some fork oil and drain/refill with what 5lbs? I will replace the seals and springs when I can allow it to be down a day or so. Too busy right now.
Monty Posted April 17, 2009 Author #4 Posted April 17, 2009 I changed the fork oil today. I added 13.5 ounces of oil to each fork, and then added 7lbs of air to the forks. It still has some bounce, but not too bad. I still have a wobble around 75-80 mph. I can make the bike wobble by just wiggling on the seat a little bit. It shouldn't wobble near that much. The steering head feels tight. I guess I will tear into the swingarm bearings next, and maybe one o' them there fancy fork braces. Gotta get rid of this wobble.
Yammer Dan Posted April 17, 2009 #5 Posted April 17, 2009 Could be 1 Rear Tire 2 Swing Arm bushings 3 Fork Brace 4 Steering head needs adjusted 5 Front Tire 6 Front Springs
Snaggletooth Posted April 17, 2009 #6 Posted April 17, 2009 By my book, if you still have the stock springs in there you might as well fill the forks with a Cherry Slushie. After changing mine to Progressives that wobble was gone. Keep in mind that I had mounted new Avons at the same time and even added a better fork brace later on but the springs they come with are junk. Mine is rock steady now.
capn eddie Posted April 18, 2009 #7 Posted April 18, 2009 i had the same thing on my 87 vr and did the fork brace,steering head bearings ,new tires ,checked swing arm and it still wobbled at the same speeds yours does. changed to solid motor mounts and wobble is gone.
Monty Posted April 19, 2009 Author #8 Posted April 19, 2009 I noticed yesterday when my wife was with me, it didn't wobble anyway near as much. I even took it up to 90 with no wobble. I wonder if I may have too much air in the rear shock. I have 45lbs in there. The manual says 14-72 psi. Does that make any sense?
Yammer Dan Posted April 19, 2009 #9 Posted April 19, 2009 I wouldn't think so. Rear tire at 40 or better? What kind of tire on rear? Run it at close to max pressure on sidewall. Check it and make sure it isn't seperating or something. I run rear shock at about 35 when solo
Monty Posted April 19, 2009 Author #10 Posted April 19, 2009 Brand new Elite 3s. 32PSI up front, and 40PSI rear, as per the manual. Had some wobble before changing tires also. Why would the wobble decrease greatly with her on the bike? She only weighs like 125lbs.
Yammer Dan Posted April 19, 2009 #11 Posted April 19, 2009 No Clue. Thats why I thought of tires. What is max for front? I run front at 40 rear at 42. And front tire will cause this very quickly and is very touchy. Raise air in it to 38 or 40 and try it.
Monty Posted April 19, 2009 Author #12 Posted April 19, 2009 Thanks. I'll give it a try Monday. Supposed to rain all day tomorrow.
Yammer Dan Posted April 19, 2009 #13 Posted April 19, 2009 Sitting here thinking about it. It is strange that passenger would make difference. Set front tire at 40 lbs rear at 42. 7 to 10 lbs for front forks and about 35 to 40 for rear shock. Maybe little more if you are over 250 lbs There is a good thread here somewhere on how to adjust forks.
sarges46 Posted April 20, 2009 #14 Posted April 20, 2009 Another thought that might help a little. Check the dampener dial. It should be set to 3 or 4 when two up and 1 or 2 for solo or wherever your preference is after checking out all positions.
Monty Posted April 23, 2009 Author #15 Posted April 23, 2009 Well Dan, I finally got the chance to ride today, so I did all the things you suggested. The front wheel bounce is not as bad now, but the wobble is still there. It starts to wobble around 80, and gets worse with acceleration. Slightest movements like shifting will set it off too. It feels like is more in the front, so I guess I'll be checking out the steering head this weekend. Thanks for the suggestions.
