Do I have to worry about the YICS when synching the carbs? I looked at the tech tip and it didn't say anything about it. On the XJ11 there is a special plug that seals it off.
If I were you I would disconnect and remove the YICS completely and get some good caps to plug everything. I doubt you would be able to tell any difference if your YICS was working perfectly. I know my bike runs a lot better after I took mine off. But, if you leave it on and it is good shape, it should not affect sync.
RandyA
