Burninator Posted April 9, 2009 #1 Posted April 9, 2009 I installed a new sealed battery. It has no connection for the small wire was connected to the original battery. As result a battery icon shows up on the display. I assume there is nothing to worry about and just ingnore the icon. Any comments?
sarges46 Posted April 9, 2009 #2 Posted April 9, 2009 Read this tech tip to resolve that little pesky light thing. http://venturerider.org/forum/showthread.php?t=489
gibvel Posted April 9, 2009 #3 Posted April 9, 2009 There's no harm in leaving it that way but there's a fix for it if it bothers you: Battery Warning Bypass
GeorgeS Posted April 9, 2009 #4 Posted April 9, 2009 If you do the Mod, be sure to install the Resistor !!! DO NOT HOOK , that wire going to the battery water level sensor DIRECTLY to 12V !!!!!!!!!!!!!!!!!!! If you do, it will FRY, the Display unit
Big Daddy Posted April 10, 2009 #5 Posted April 10, 2009 I installed a new sealed battery. It has no connection for the small wire was connected to the original battery. As result a battery icon shows up on the display. I assume there is nothing to worry about and just ingnore the icon. Any comments? Hey Christian! If you do this job shoot me your addy and I will mail a couple resistors to ya!
