Naked Rider Posted April 7, 2009 #1 Posted April 7, 2009 what if any brand fits a half helmet for a intercom or do i have to buy a diffrent helmet?
firewalker Posted April 7, 2009 #2 Posted April 7, 2009 I personally use the IMC headset for use with a half helmet, it is a stand alone product that wraps behind the head. You can look at and order here http://www.sierra-mc.com/proddetail.asp?prod=IMC-HS-G45U
Magnum Posted April 7, 2009 #3 Posted April 7, 2009 firewalker said: I personally use the IMC headset for use with a half helmet, it is a stand alone product that wraps behind the head. You can look at and order here http://www.sierra-mc.com/proddetail.asp?prod=IMC-HS-G45U I have two of these and have been very happy with them.
eagleeye Posted April 7, 2009 #4 Posted April 7, 2009 Edset makes a quality headset, Check them out online, and they should have what you need for your half helmet. Steve
RoadKill Posted April 7, 2009 #5 Posted April 7, 2009 J&M now has a headset for a 1/2 helmet that slides between the helmet outer shell and liner and will go easily in and out. It does not require pockets in the strap. I use this one, which I got form www.cyclegadgets.com and have been very pleased with it.
waterbug Posted April 20, 2009 #6 Posted April 20, 2009 Does anyone use the chatterbox set for there bikes? They have a new noise reduction set and they seem cheaper than the others? I am looking to get something also and thought I would ask on this instead of starting another thread. Thanks everyone.
slick97spirit Posted April 20, 2009 #7 Posted April 20, 2009 I use the chatterbox & have not had any problem with them.
kenw Posted April 20, 2009 #8 Posted April 20, 2009 I've had several brands and would go with the Edsets!
waterbug Posted April 24, 2009 #9 Posted April 24, 2009 Has anyone heard of some heads sets made by omc? I was told about some that you can wear with or with out a helmet and they work great and priced around 75 bucks from what I was told but I cant find them anywere.
venturega Posted April 24, 2009 #10 Posted April 24, 2009 I think it is IMC. I just bought a set from Chromeworld.com for $69 and will be using them this weekend. As long as the half helmet doesn't push them into my ears I think they will be OK.
Guest BluesLover Posted April 24, 2009 #11 Posted April 24, 2009 I used the IMC model on the Venture. Worked very well with the half helmet - got the idea from Gary N. Cheers,
