Bubbajbi Posted August 8, 2007 #1 Posted August 8, 2007 Ok, so late last night after spending about an hour on this site I got inspired and went out to work on Cassy (thats the name of my RSV). I am trying to remove the saddle bag but I cannot figure out how to unplug the CD changer to get it out of the saddle bag. HELP! I darn-near broke the plug trying to get it off. Somebody here has to know how to do this. Also, I was messing with the CB antenna and it just lifted off of its mount. Is it supposed to do that or did I break it? Need input!!!!!!!!!!!!! (P.S. I am removing the saddle bag rails and the CD changer just in case anyone is interested in purchasing them.)
Freebird Posted August 8, 2007 #2 Posted August 8, 2007 I got read of the CD changer a long time ago but I seem to remember a release tab on the edge that has to be pressed before it will pull out. As for the antenna, not, it should not just lift off. That was a problem with the antennas on the '99 models. They are a terrible design. I replaced mine with after market antennas for that very reason. If you haven't had any problems with the CB, you are very lucky. Mine would barely transmit with that problem and often squealed very loudly when I hit the transmit button.
Bubbajbi Posted August 8, 2007 Author #3 Posted August 8, 2007 I haven't even tried to use the CB yet. I don't know that I ever will because I have a two way com that attaches to my helmet. For now I just have the antenna off so it doesn't fall of while I am under way. I will look for the tab on the CD player. It is pointless to have a big bulky CD player when I have an ipod. And check out how I mounted mine. http://www.venturerider.org/forum/showthread.php?t=13469
venturejockey Posted August 9, 2007 #4 Posted August 9, 2007 My CD player has a zip tie holding the plug in place. Cut the ziptie and it comes right out.
99silver Posted August 9, 2007 #5 Posted August 9, 2007 My CD player has a zip tie holding the plug in place. Cut the ziptie and it comes right out. What Eric said ! Gary
curt99rsv Posted August 9, 2007 #6 Posted August 9, 2007 I might be interested in your saddlebag rails...I'll PM you. Thanks, Curt
curt99rsv Posted August 9, 2007 #7 Posted August 9, 2007 Oh, I almost forgot, my old CD changer had a black ring just where it plugged in. You pulled the ring away from the changer and then unplugged it. Curt
Bubbajbi Posted August 10, 2007 Author #8 Posted August 10, 2007 Oh, I almost forgot, my old CD changer had a black ring just where it plugged in. You pulled the ring away from the changer and then unplugged it. Curt Yeah that worked! I was pulling on the plug part and not the ring. As soon as I grabbed the ring and pulled it came right out. Thanks.
Raymond Posted January 12 #9 Posted January 12 How do you make the CD player go to the second CD or the third CD or the 4th CD I'm a brand new owner of a 2009 Yamaha Royal Star Venture
