When installing the new progressive springs at what point in the procedure does one refill the fork oil (13.5oz.) into each tube? I will be changing seals and all. Thanks :doh:
Your New Progressive Springs, are made of Thicker Material, then the OEM Springs.
SO: They take up More Cubic volume in the Tubes.
So: There is less space left for Oil.
Therefore, you must use Less Oil. About 1 1/2 oz. Less. The Oil level should be set to 5 1/2 Inches from the top of tubes, With the Forks Fully Compressed to the UP position.
Check the Instruction sheet that came with your new Springs. Its explained there.
:no-no-no:
