johnny-canuck Posted March 28, 2009 #1 Posted March 28, 2009 Has anyone installed a Bad Boy or Stebel horn inside the lower fairing or in the front cowling on a second gen? I have the plain jane Bad Boy and don't want to mount it on the side by the engine. I thought it would fit in where the factory horn is but that looks tight. I haven't put much effort inot it yet as I just got the horn. Hoping someone has already done it and save me a bunch of time trying different locations. Mounting it on 2007 Midnight Venture. Thanks, John
Reaney in NH Posted March 28, 2009 #2 Posted March 28, 2009 The Stebel will fit where the Stock horn is on the lower right side. I juswt installed one yesterday. Its AWESOME!!!
Ivan Posted March 28, 2009 #3 Posted March 28, 2009 Do these horns need to have a different circuit run to them? I am considering one on my old XS11, and was wondering if they take a huge amount of current, that would require a relay setup.
Dano Posted March 28, 2009 #4 Posted March 28, 2009 Do these horns need to have a different circuit run to them? I am considering one on my old XS11, and was wondering if they take a huge amount of current, that would require a relay setup. Most definately yes on the relay. Stock wiring is not heavy enough to properly fire the compressor motor. Advise it greatly for anyone installing an air horn. Dan
jburrell Posted March 29, 2009 #5 Posted March 29, 2009 I jsut installed the horn on the orig location. Do not install in the fairing.You need the sound of the horn to be pointed down or clost to pavement so sound can "bounce" to be effective. My old air horns were under saddle bags and pointed backwards and therefor were not effective in warning people in front of me. Setbel says you reallyneed the sound to bounce and vibrate off somethng. It is easy to intall where the old horn goes. INstructions and a bracket from Carbon one are here on this site. I would put the one you have parhaps low on the l side of the bike and then get the chrome for the left side. You will know for sure then that they hear you and its a good investment. I started with the chrome one and will add the other in a couple of months when I have a few $$ again. Hope this helps
TEW47 Posted March 29, 2009 #6 Posted March 29, 2009 I installed mine on the right side, rear bolt of the passenger floorboards. tew47
dragerman Posted March 29, 2009 #7 Posted March 29, 2009 Has anyone installed a Bad Boy or Stebel horn inside the lower fairing or in the front cowling on a second gen? I have the plain jane Bad Boy and don't want to mount it on the side by the engine. I thought it would fit in where the factory horn is but that looks tight. I haven't put much effort inot it yet as I just got the horn. Hoping someone has already done it and save me a bunch of time trying different locations. Mounting it on 2007 Midnight Venture. Thanks, John Hi John, yes I've just installed a plain Bad Boy horn in the front fairing and am very pleased with how it sounds. I found Freebird's post very helpful; http://www.venturerider.org/forum/showthread.php?t=500 I ran a seperate fused wire from the battery to a relay and installed a seperate horn switch, my stock horns are still opperational.
Guest jet man Posted March 29, 2009 #8 Posted March 29, 2009 I installed a bad boy horn using the existing mounting bracket. I have mine sticking out from the side and the relay right next to it. I was able to use both existing wires from the original horn with out splicing them and then just added two more wires from the relay to the horn. Hope this helps. I will try tomorrow to add some pics of what mine looks like.
Guest Saddletramp Posted March 29, 2009 #9 Posted March 29, 2009 I was given a plain jane stebel, not chrome, and because of this I didn't want to mount it where it could be seen. I placed mine inside the fairing on the frame work for the headlight pod and sound system. 11,000 miles with out a problem and still plenty of volume. Do use a relay, the draw is too much for the original circuits.
johnny-canuck Posted March 29, 2009 Author #10 Posted March 29, 2009 Thanks Everyone for your input. I have decided to put this one in the front fairing. I found Freebird's instructions right on the money. Thanks Dragerman for the link. I now have the front cowling laying on the floor. I need to get a few parts and then I'll hook 'er up. If I need a second, I'll probably put it on the right by the engine (chrome of course). This site is great. All the free technical help I need Now if I could just get rid of all the snow between my shed and the driveway John
dragerman Posted March 29, 2009 #11 Posted March 29, 2009 (edited) Thanks Everyone for your input. I have decided to put this one in the front fairing. I found Freebird's instructions right on the money. Thanks Dragerman for the link. I now have the front cowling laying on the floor. I need to get a few parts and then I'll hook 'er up. If I need a second, I'll probably put it on the right by the engine (chrome of course). This site is great. All the free technical help I need Now if I could just get rid of all the snow between my shed and the driveway John I took some photo's of where I put my horn today and will post them under a new thread so have an eye for it. I'll also be showing pics of my headlight mod and horn switch. Sorry but I can't help you with the snow except to encourage you that it won't be long now! ... I'd post the pictures now but I was just heading down to the dock with a coffee to watch the sun set!! Edited March 29, 2009 by dragerman
EFudd Posted March 30, 2009 #12 Posted March 30, 2009 Wow, installed the horn today. Has a grrrrrrrrreat sound and is loud. Thanks to all those on the forum that have provided guidelines and advice. Worked first time!!!! Bought the bracket from Carbon One and the horn and wiring harness from Twisted Throttle. Cut the harness to length, put the wires in a protective split-tube and replaced the Stebel horn end connectors on the harness with right angle connectors to keep clear of the exhast.
jemorrisonjr Posted March 30, 2009 #13 Posted March 30, 2009 After I put one on my bike I had to install one on a friends bike.... We now have 5 in our group with the Stebel.....
