fixit3546 Posted August 6, 2007 Posted August 6, 2007 Well i got the paint almost finished up and it was lookin fair. Got down to clear coeting (second coat) the last part and i knocked off my front fender into the grass, (no paint booth) turned around to see what happened and knocked off the headlight ring and the false tank cover..............I'll stop right there. the rest of the story is'nt good for mixed company. I'll have to fix the clear coat later, now i have a new problem...... Got all the parts back on and it looks better even though it is ****** up. So i started checkin to see why it wasnt idling right and i found that the #2 cylinder carb boot is busted. now i gotta have one. Anybody have a spare? It is the left front cylinder. looks like oil has dripped out of the filter housing and onto the rubber boot. i'm pretty sure this is what caused it th bust open.,:sick:, !!!
bongobobny Posted August 6, 2007 Posted August 6, 2007 Bummer!!! Would love to see pictures with pieces of grass stuck to clear coat:stirthepot: I don't have any spare except what's on the '85 but I'm probably going to need them as it looks more and more like I'm gonna turn it into a running bike again. I'm sure someone has one, if not they go fairly cheap on ebay...
SilvrT Posted August 6, 2007 Posted August 6, 2007 pieces of grass stuck to clear coat Looks like fixit has created a new paint scheme... mebbe just leave the grass on and put several more clear coats over top for that "deep embedded look"...sorta like "floating grass"!!! :rotf:
fixit3546 Posted August 6, 2007 Author Posted August 6, 2007 Looks like fixit has created a new paint scheme... mebbe just leave the grass on and put several more clear coats over top for that "deep embedded look"...sorta like "floating grass"!!! :rotf: You are not right dude. But; it's a thought.
Rick Butler Posted August 6, 2007 Posted August 6, 2007 James, When you say "Carb Boot" do you mean the intake that is bolted to the head with the carb on the top? If so, I think I have a set off of a 1300 that should work. Rick
fixit3546 Posted August 6, 2007 Author Posted August 6, 2007 James, When you say "Carb Boot" do you mean the intake that is bolted to the head with the carb on the top? If so, I think I have a set off of a 1300 that should work. Rick That's exactly right Rick.
Mean Dog Posted August 6, 2007 Posted August 6, 2007 James, Man that Sucks! I am so sorry to hear of your trouble painting the bike. I did a paint job on a customer car one time and applied the first coat of clear. It looked like a mirror finish. I went to get a cup of coffee and to let the paint flash and when I returned I found that the entire car had frosted white due to the humidity and incorect reducer temp. I feel your pain my brother! It can be fixed with time and sandpaper but it is a royal pain! http://smileys.smileycentral.com/cat/36/36_1_25.gif Dog
fixit3546 Posted August 6, 2007 Author Posted August 6, 2007 Hey Mark I did put it all baqck together and will fix it at some time in the future. I need thet intake boot bad though. Let me borrow one of yours....?
