I switched to Windows Explorer 8 A few months ago
and I am liking it.. I was messing around with the links bar/ favorites bar
across the top and I turned them in (tiny) small icons.
I have been recking my brain trying to get them back
to there normal size. any help would be appreciated.
Thanks,
Jeff
IE8 is pretty much the same way. Just right click on the menu bar and then select customize. It will give you options of large icons, icons with text, etc.
Well heck, I did a screen shot to show you what I see but this awful internet connection at the hotel is not letting me upload files. I'll post it later when I have a better connection.
Nope tried that as well. right now it is set just like yours.
Tell ya what make them bad boys tiny little frigging
squares like mine then try to make them go back to
the normal way. *lol*
Don , here is the screen shoot of what I am talking about.
[ATTACH]27706[/ATTACH]
I have tried it all. wonder why it is so hard to make it
go back? seems as if that option went away as well.
-Notice the TINY Icons
Jeff
OK....here's what it looks like has happened. First of all, when you right click on the menu bar, you should be able to deselect the "Favorites" bar to get rid of all of those. If you wish to keep them, then right click on any one of those tiny icons and then choose "Customize Title Widths". You will see that the choices are "Long Titles", "Short Titles", "Icons Only". You can choose to add the titles to them if you wish. I personally have the favorites bar turned off and just use the drop down menu for my favorites. Actually, I don't even USE IE8 but if I did, I would have it turned off.
You have a LOT of favorites added to the bar. Don't know why or how you added so many because I think you have to add each one manually. When you save a page to your favorites, you have a choice of adding them to your favorites menu or to the favorites bar. You've added a LOT of them to the bar. To get rid of them, you have to right click and choose "delete".
Don
Thanks Don Now that one i did not think of. sheesh
so simple.. here I am trying to find it all in boxes
and not right clicking on the icons ! DUH!!!!
[ATTACH]27712[/ATTACH] FIXED NOW!
Now fix one more thing and I will leave you alone
for at least a week I promise *he he he*
Under the box that I am typing this. I lost the main Smileys
I checked something and now all I got is this guy :happy-emoticon: to click on
Is there a way I can set it back to default?
Thanks Much
Jeff
