I was hoping for some suggestions on where I could pick up a "Trailer Isolation Relay" in Canada. I need to wire up my Aluma MCT trailer and thought it would be wise to use a relay kit to protect the bikes wiring.
I was also wondering how many actually use a relay kit. Is it really necessary or will the Venture handle the trailers LED lights without overloading anything.
Thanks Jim
Check out CTC, they have lots of that type of stuff and something may work for you. For myself, I wouldn't bother, just wire it direct as usual, there's not that much more draw, only when you brake.
Go to a place that sells Travel and pop up tent trailers, that's where I found mine and it was just as cheap as ordering on line. On line and have it shipped to the house, is the best other alternative.
Brad
