Tartan Terror Posted March 19, 2009 #1 Posted March 19, 2009 In the hinge are of the tape deckI know there is one spring that pushes the door open when you press the door to release it. I found one when I took it out. Now what Im not sure of becuse it kind of fell part when I was taking the door off for paint and one fell out and i thought there was another. Is there one spring or two?
T.J. Posted March 19, 2009 #3 Posted March 19, 2009 Spring has sprung around here too. Great to have the warmer weather.
KiteSquid Posted March 19, 2009 #4 Posted March 19, 2009 Did you look at the drawings in the parts list in the VRTech section?
Tartan Terror Posted March 19, 2009 Author #5 Posted March 19, 2009 Actually I cant find that diagram but if you all say one spring then Im good. I have one.
Guest Lightnen Posted March 19, 2009 #6 Posted March 19, 2009 Well if anyone needs a spring let me know for I'm removing my door later today to install gauges..
SilvrT Posted March 19, 2009 #7 Posted March 19, 2009 If I recall correctly, there is only one spring... and I have the empty cassette box complete with the door and spring intact .... I'm at work so will check tonight when I get home re: one or two springs but I'm pretty sure it's just one.
KiteSquid Posted March 19, 2009 #8 Posted March 19, 2009 Actually I cant find that diagram but if you all say one spring then Im good. I have one. The drawing I was referring to is HERE HOWEVER once looking at it, I cant find the door...... sorry.... look at the last page and it is there, but not as a separate unit. Also note the note that says the drawing is continued on the next page.....
Tartan Terror Posted March 19, 2009 Author #9 Posted March 19, 2009 If its just one then Im golden but if its two can I get the spring from you if you dont need it when you take the door off?
Guest Lightnen Posted March 19, 2009 #10 Posted March 19, 2009 Just removed my casset deck the SPRING in on the Left side of door when it faces you.. Only one spring.. hope mine is the same as yours.. RVS 06
big mike Posted March 19, 2009 #11 Posted March 19, 2009 Yep, only one! Just had mine apart for paint and that sucker can be tricky to put back together. But it only has one! Big Mike:080402gudl_prv:
SilvrT Posted March 19, 2009 #12 Posted March 19, 2009 Just removed my casset deck the SPRING in on the Left side of door when it faces you.. Only one spring.. hope mine is the same as yours.. RVS 06 Great... my memory is working then!! LOL
Tartan Terror Posted March 20, 2009 Author #13 Posted March 20, 2009 Guys thanks for all the help. Im in good shape now. Just need to monkey with it to get it all back together!
Cougar Posted March 20, 2009 #14 Posted March 20, 2009 Gunna be A LOT of those springs around after all the Gauge Mods going on
Tartan Terror Posted March 20, 2009 Author #15 Posted March 20, 2009 I know I was real tempted to do that too. Actually I was thinking another guage route but just in the thinking stage. I got so much to go together that Ill attack that next year.
Cougar Posted March 20, 2009 #16 Posted March 20, 2009 I have all my parts for the project now.. but gunna wait for a bit. It might even be next winters project! But it is nice to know how folks are coming along with this for a while as well. and I can't wait to have an extra spring laying around!
