Freebird Posted August 2, 2007 Posted August 2, 2007 Greasing the Rear Drive Splines and greasing the Hub Pins on the RSV By Tartan Terror NOTE: Most of us here would recommend Honda Moly60 as the grease of choice for this application. It will do a great job and last much longer than other types. First thing you will need to do is raise the bike on a lift and remove the rear tire. For these operations look for the instructions in other articles in this tech area. After you have the wheel removed lay your rear tire flat on the ground or on a surface that you can work on it with the spline side facing up (Looks like a gear). http://www.venturerider.org/hub/Image1.gif I removed the dust shield (Rubber ring around the base of the gear) but it is not necessary unless you want to clean everything thoroughly. Wipe around the top edge of the gear clean and you will find a snap ring. Look carefully because it is hard to miss. Use a pair of snap ring pliers that open to remove the ring and lift it off or gently grab it with a pair of pliers being careful not to stretch the ring. If you do not remove this ring you will be unable to remove the pins from the hub (I know this Cuz this dummy tried to do it!) After you have removed the ring pull on the gear and the pins should slide out. http://www.venturerider.org/hub/Image2.gif Once you have removed the pins clean off any rust on the pins with a piece of scotch brite so that they are smooth. Generously apply grease to the pins. I used lithium based grease but any good water proof grease will do. Below you will see a picture showing the pins, Snap ring, scotch brite pad, and dust boot ring. http://www.venturerider.org/hub/Image3.gif Reinsert the pins into the bushings and replace snap ring. Once again be careful not to stretch out the ring as it needs to fit tightly to keep it in the groove. If you removed the dust boot also replace that and make sure it is properly seated. Apply grease to the splines on the hub. http://www.venturerider.org/hub/Image4.gif And also on the splines in the differential. It will squeeze out any extra grease then you lift the wheel back up and slide the hub splines into the differential splines but here is where most of the noise is coming from. http://www.venturerider.org/hub/Image5.gif It’s as easy as that. Like I said before refer to the other articles in this section to reinstall the rear wheel. Now Get out and Ride it like you stole it!!!
