hairman Posted March 7, 2009 #1 Posted March 7, 2009 I bleed my clutch today and I got all the old fluid out that I could by doing it this way. The bottom of the reserve looked like liquid lead in it. I took a rag and got all of that out that I could. The fluid looked like strong coffee or a pepsi. The clutch slipped a little bit today when I went to pick up my son from school, but it was better than yesterday. I am going to try to post a picture of what the fluid looked like. Is there a better way to change the fluid than the way I done it? If so let me know. Appreciate the help. Thanks hairman
1BigDog Posted March 7, 2009 #2 Posted March 7, 2009 You need to continously flush fresh fluid through it until its all clean looking. A MityVac works well for this.
RedRider Posted March 7, 2009 #3 Posted March 7, 2009 The MityVac is great, but you may want to just work with a SpeedBleeder. They cost about $8. Speedbleeder.com. You will need to do a search on here for the correct p/n. While you are at it, get the bleeders for the front brakes (need 2) and rear brake. Get the bleeding bag along with them. It is money well spent. Now that I think about it, I should bleed mine this weekend. RR
GeorgeS Posted March 7, 2009 #4 Posted March 7, 2009 Just keep pumping thru new fluid, until whats comeing out the bleed port is clean New fluid.
Condor Posted March 7, 2009 #5 Posted March 7, 2009 I bleed my clutch today and I got all the old fluid out that I could by doing it this way. The bottom of the reserve looked like liquid lead in it. I took a rag and got all of that out that I could. The fluid looked like strong coffee or a pepsi. The clutch slipped a little bit today when I went to pick up my son from school, but it was better than yesterday. I am going to try to post a picture of what the fluid looked like. Is there a better way to change the fluid than the way I done it? If so let me know. Appreciate the help. Thanks hairman That's double ugly fluid....
IH Truck Guy Posted March 7, 2009 #6 Posted March 7, 2009 I bleed my clutch today and I got all the old fluid out that I could by doing it this way. The bottom of the reserve looked like liquid lead in it. I took a rag and got all of that out that I could. The fluid looked like strong coffee or a pepsi. The clutch slipped a little bit today when I went to pick up my son from school, but it was better than yesterday. I am going to try to post a picture of what the fluid looked like. Is there a better way to change the fluid than the way I done it? If so let me know. Appreciate the help. Thanks hairman Wow,that looks like the spitoon in my truck...:yikes: No matter how you change the fluid,you have to keep doing it till you get clear fluid.....
Chinto Posted March 9, 2009 #7 Posted March 9, 2009 Is this the first time you replaced the clutch fluid on your 99RVS? What did the fluid look like thru the sight glass?
Condor Posted March 9, 2009 #8 Posted March 9, 2009 Is this the first time you replaced the clutch fluid on your 99RVS? What did the fluid look like thru the sight glass? The more moisture your brake and clutch fluids absorb, the darker it gets. Causes lots of problems from rusting up the slave walls, forming inline crystals, to boiling when the engine is hot, and causing the clutch to slip, and the brakes to drag and over heat. There's a reason why the service manual recommends bleeding the brakes and clutch every two years. I do mine every year at the start of the riding season. Fresh fluid should look like clear water, when it starts looking amber it's time to get it out of there....
