tooldood Posted July 30, 2007 Posted July 30, 2007 Ok... I just changed out my stator on my 86. I get it back together, all buttoned up... and changed the oil while I'm at it... fire it up! Hmmmm... What's that knocking noise from the left crankcase cover?? I don't have any leftover parts, so any ideas??
Fvogt Posted July 31, 2007 Posted July 31, 2007 Better take it back apart and see. I know of nothing that could nock in the case unless you left something inside that don't belong Fred:confused24:
CrazyHorse Posted July 31, 2007 Posted July 31, 2007 Did you put the starter clutch parts back in the right way?
Marcarl Posted July 31, 2007 Posted July 31, 2007 Did it go back together easy or was it a lot of fun? The shifter linkage behind the cover needs to in the up position, it likes to be in the down position due to gravity but you need to keep an eye it to make sure it's right.
BOO Posted July 31, 2007 Posted July 31, 2007 Better count all your tools, sounds like you may have left something in there. :rotf: Jerry
tooldood Posted July 31, 2007 Author Posted July 31, 2007 I took off the chrome cover and the small plate inside the cover (around the shaft) was a bit looser than t seems like it oughta be. :bang head: Well, it looks like a bit more time tomorrow taking it apart... looking it over... and re-assembly. :bang head:
Dano Posted July 31, 2007 Posted July 31, 2007 When you do it once, it's an experiment. When you do it twice, you're an expert. If you do it three times, you're a genius at working on these bikes!
GeorgeS Posted August 1, 2007 Posted August 1, 2007 Print out a copy of that section of the IPC, Yamaha On line Parts IPC
tooldood Posted August 1, 2007 Author Posted August 1, 2007 When you do it once, it's an experiment. When you do it twice, you're an expert. If you do it three times, you're a genius at working on these bikes! Well, I'm no genius... I found that I had 1 piece (a small plate) in the wrong spot and since I had stripped off the head of one of the pan head bolts the replacement had a bigger head. That combination caused the racket. All better now.
