GeorgeS Posted August 26, 2006 Posted August 26, 2006 At the Large White Plug, with the 3 #14 wires comeing from the Alternator: Do the following: Measure the AC voltage on each wire. You can stick the meter probs into the end of the White Plug. ( located just behind left rear cylinder, White connector, with 3 white wires thru it ) With Engine running, you should Read 9 to 15 volts AC, ( thats AC, not DC ) on each wire. If the voltage on " one" wire is substantially , Lower then the other two, then your Alternator is failing. This is a much better way to check it then useing the Resistance reading method given in the Service Manual.
Yammer Dan Posted August 26, 2006 Posted August 26, 2006 Yes, That is a easy check. Will try to remember that one.
