timgray Posted February 24, 2009 Posted February 24, 2009 I just got mine for $80.00 shipped brand new. the British pound is falling and the dollar is not falling so badly. I got a new one shipped for what most guys are asking for their used ones.
Condor Posted February 24, 2009 Posted February 24, 2009 I just got mine for $80.00 shipped brand new. the British pound is falling and the dollar is not falling so badly. I got a new one shipped for what most guys are asking for their used ones. I heard about the dollar getting stronger on the world market just yesterday, and can't figure it out. Maybe RSV's will start getting more affordable That's a great price for a CarbTune.... For anyone on the fence now's the time to buy before they figure out that the dollar ain't worth much either......... That may be the reason crude oil is still down.
BuddyRich Posted February 24, 2009 Posted February 24, 2009 Yea, I got another because I lost the first one in the move somewhere. Went ahead and got the case and it all came to like 92
wasabe58 Posted February 24, 2009 Posted February 24, 2009 Hey Tim, Can you let me know where you ordered your carbtune from. I am needing one and would like to order one up. Artie
BoomerCPO Posted February 24, 2009 Posted February 24, 2009 I just ordered mine.....and told them I read about it here on VentureRider.org too. Could someone post a list of any special tools I will need to do this job with?
timgray Posted February 24, 2009 Author Posted February 24, 2009 nothing special. just reallllly long screwdrivers. the longer the better if you dont want to remove all the lower fairing parts. I have a 18" long 1/4 inch flat head that works perfect on my 83. Oh long nose bent pliers to remove the clips holding on the rubber plugs on the vac ports.
bongobobny Posted February 24, 2009 Posted February 24, 2009 Heat resistant gloves for rehooking your lines when you're done, so you don't get burned on the exhaust...
jasonm. Posted February 25, 2009 Posted February 25, 2009 One thing you should know. 1st the carbtune is an excellent item for carb syncing. 2nd, it works on a leak principle. Meaning when connected , it is not just a vacuum that raises the rods but the air traveling around under and over the rods. A vacuum alone on a solid object cannot defy gravity.There is a small hole under each rod which causing a slight lean condition. As the air rushes thru this tiny hole under and around the rod it is raised. JUST remember not to tune your low speed screws with this device connected. I have one...I like it.
BoomerCPO Posted February 25, 2009 Posted February 25, 2009 Hey Jason if you are experienced at using the Carbtune mebbe we could hook up to do my scoot? I don't have a clue as to how to do this procedure and my tools are limited......Shoot me a PM if this could work for you. I'd gladly buy Lunch. Regards.........Boomer
50btripn Posted February 27, 2009 Posted February 27, 2009 I think I am gonna break down and take advantage of this while the U.S. dollar is "strong". But I have a question. I have a 2007 Venture. The Morgan Carbtune website also advertises a "CARBTOOL"...with my 2007 Venture, is this carbtool necessity?
GG54172 Posted February 27, 2009 Posted February 27, 2009 (edited) A vacuum alone on a solid object cannot defy gravity.. I do not know whether morgan carbtunes leak or not, but your statement is completely false. A vacuum on one side of an object can lift an object. So long as the difference in pressure, multiplied by the surface area of the pressure is higher than the mass of the object. So, take a 10lb bowling ball, touch a 1.5" vacuum hose to the ball. It will take 10lbs/(pi*(0.75"^2))=5.659psi of vacuum to lift the bowling ball. Or if you have a typical household vacuum that can create 1/2psi of vacuum it will take 20 square inches or just little bit larger than a 2.5" hose to lift that same bowling ball. Take that same vacuum, a system that doesnt leak, and a large enough surface area and you can lift tons. Need another example? I have a thermometer hanging on my front window with a suction cup. Using vacuum only, that thermometer defies gravity all year long. Edited February 27, 2009 by Gregory Gill
buddy Posted March 5, 2009 Posted March 5, 2009 Just wanted to say Thank You for this info. on the Morgan Carbtune. I been wanting one for some time. Should be in sometime next week, now I can do away with the home made one. Thanks Guys Buddy
SteveW Posted March 5, 2009 Posted March 5, 2009 I ordered one a week ago and recived it yesterday. I synced the carbs on my 1982 Yamaha xj750 that I have been working on the past few months. They were way out of sync and after setting them the bike really runs great. No more stumble and quick throttle responce. I'm very happy with the product and the quick shipping.
GaThumper Posted March 27, 2009 Posted March 27, 2009 Thanks for the tip on the exchange rate! I went ahead and ordered one today, I've been thinking about one for years and just never got around to buying it. This will be great for my '79 GS1000E inline 4 and the V4 Venture I hope to buy this summer!
RandyR Posted April 6, 2009 Posted April 6, 2009 I ordered mine today directly from Morgan in the UK with toolbag. thanks for the pointer. price was 65pounds delivered which converts to $95.56 at today's rate.
