Cougar Posted February 22, 2009 #1 Posted February 22, 2009 (edited) I have not seen this until today.. Kinda Neat. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99887 Here is the pdf user manual. http://www.harborfreight.com/manuals/99000-99999/99887.pdf Look as if you can also add the adapter as well. 1100 pound maximum lift capacity Only $11.99 to ship... Ummm Jeff Edited February 23, 2009 by Cougar
BigBoyinMS Posted February 23, 2009 #3 Posted February 23, 2009 Cool! The only problem that I could imagine... the 30 mins that it takes to pump it to that height.
Freebird Posted February 23, 2009 #4 Posted February 23, 2009 I don't like it. It would pretty much totally block access to one side of the bike. I think a conventional lift or a table makes much more sense.
Carbon_One Posted February 23, 2009 #5 Posted February 23, 2009 I don't like it. It would pretty much totally block access to one side of the bike. I think a conventional lift or a table makes much more sense. Gonna have to agree with Don here as well. Yea it'd probably do the job but you can find cheaper and better jacks to do the job. Also most of the mc/atv jacks have a lift rating of 1500 lbs where this one list 1100lbs. I'll second BigBoys opinion on stroking that puppy too. Larry
Hardhead Posted February 23, 2009 #6 Posted February 23, 2009 I have one that is very similar to this one. With the adapter available from this sight works great. Jack is fast actingand goes up very quickly. The Venture weighs less than 1000# unless you are on it. If you need to swap sides let it down and pick from the other side. 30 " of lift is ample for most work and makes changing tires a snap.
az1103 Posted February 23, 2009 #7 Posted February 23, 2009 I don't like it. It would pretty much totally block access to one side of the bike. I think a conventional lift or a table makes much more sense. I'll second that!
saddlebum Posted February 23, 2009 #8 Posted February 23, 2009 you sure its a bike lift I see wrist straps :rotfl:
