I don't like it. It would pretty much totally block access to one side of the bike. I think a conventional lift or a table makes much more sense.
Gonna have to agree with Don here as well. Yea it'd probably do the job but you can find cheaper and better jacks to do the job. Also most of the mc/atv jacks have a lift rating of 1500 lbs where this one list 1100lbs.
I'll second BigBoys opinion on stroking that puppy too.
Larry
I have one that is very similar to this one. With the adapter available from this sight works great. Jack is fast actingand goes up very quickly. The Venture weighs less than 1000# unless you are on it. If you need to swap sides let it down and pick from the other side. 30 " of lift is ample for most work and makes changing tires a snap.
I'll second that!
