I have been seeing a little coolant on the engine. This is on a 1st gen 1992 model. I see some under the bike, usually the next day after it has been riden. There is a small hole(I suppose it is a drain or something on the side of the head). The hole is under the plate on the side on the cylinder block. It looks like some has drained under the plate. It nevers does it while it's hot, or when I look at it for that matter. Beside the spark plug there is a large allen head bolt. From looking at the parts break down, there are o'rings in there somewhere. Anyone ever seen this before or had to replace these o'rings. Anything special I need to know before taking out this plug?:cool17:
BTW, it's #14 under the crankcase listing....... These plugs dry up and can start seeping. I replaced mine last year during the rebuild.
Yur just too good there, Mini!
  sleeperhawk said:
What :( You do not allow the boss on the computer anymore :no-no-no::no-no-no:
He left his laptop at the RV didn't want to get it broke this weekend in the dungeon.:rotf::rotf::rotf::rotf::rotf::rotf::rotf:
Margaret
