waterbug Posted February 17, 2009 #1 Posted February 17, 2009 I have a 08 venture and I rode it to work today and on the way back when i get around 50mph I hear a hum sound in the rear almost like the tires on a truck make but not quit or a gear humming, any idea? It has the factory dunlops on it and I have never heard it before today and I feel alittle vibration also but that could be normal and I am trying to sence things. Thanks for any imput.
Squidley Posted February 17, 2009 #2 Posted February 17, 2009 Could be a few things....did you look to see if the tires are cupped front and back. How is the rear drive lube oil level, and it could be dry splines. These are just a couple off the hip ideas.
Eck Posted February 17, 2009 #3 Posted February 17, 2009 One possibility could be the tread on the Dunlop tire that makes the sound your talking about. Does the sound seem to disappear when you lean from one side or the other? Another possibility could be the favorite whine that you will see many here talk about. Some change clutch baskets to try to eliminate it. You can also page down to the bottom of this page and read other posts about rear end sounds and noises. One of the posts may explain exactly what your talking about.
waterbug Posted February 17, 2009 Author #4 Posted February 17, 2009 the bike has alittle over 4200 miles on her, I havent looked at the tires not to say its not that but I have been in cars with that and it doesnt sound like tires being cupped. I didnt get it over 60 but the noise didnt go away, it wasnt so much a whine and it sounds like the rear of the bike not the engine or I basket, from 55 to 40 as you slowed it got a deeper sound and it stayed even when I pulled the clutch in and would coast. I am going to call the dealer and get it taken in just to be safe but kinda wanted to get some ideas first. thanks
Sleeperhawk Posted February 17, 2009 #5 Posted February 17, 2009 the bike has alittle over 4200 miles on her, I havent looked at the tires not to say its not that but I have been in cars with that and it doesnt sound like tires being cupped. I didnt get it over 60 but the noise didnt go away, it wasnt so much a whine and it sounds like the rear of the bike not the engine or I basket, from 55 to 40 as you slowed it got a deeper sound and it stayed even when I pulled the clutch in and would coast. I am going to call the dealer and get it taken in just to be safe but kinda wanted to get some ideas first. thanks Most of get rid of the tires by the 6000 mile mark on those Dunlops, the older they got, the nosier they get.
KiteSquid Posted February 18, 2009 #6 Posted February 18, 2009 My vote is for the tires. Get some Avon Venoms under your scoot soon.
GeorgeS Posted February 18, 2009 #7 Posted February 18, 2009 Well you better examin the tire before you do any more rideing !!
Brake Pad Posted February 18, 2009 #8 Posted February 18, 2009 I have a 08 venture and I rode it to work today and on the way back when i get around 50mph I hear a hum sound in the rear almost like the tires on a truck make but not quit or a gear humming, any idea? It has the factory dunlops on it and I have never heard it before today and I feel alittle vibration also but that could be normal and I am trying to sence things. Thanks for any imput. where you still in 5th gear? my 07 hums like that when, I'm in too high a gear for the speed. Welcome to the world of owning a Venture
waterbug Posted February 18, 2009 Author #9 Posted February 18, 2009 It makes the noise in 4th or 5th and if I pull the clutch in. I looked at the tires over the weekend and they look new still have great tread on them and all. It just seems funny that I didnt hear it this morning and then I hear on the way back. I hope its not the tires as I would like to get some money out of them as far as milage goes. I am going to check the fluid in the rear end after work wed if I have time and see what it looks like. I had all the fluids changed after the break in and just changed the oil over last weekend. thanks
ToRide1 Posted February 18, 2009 #10 Posted February 18, 2009 Its the OEM dunlop howlers thats making the noise and plan on replacing them at 7000 to 8000 miles and get off it if the road is wet the OEM Dunlops are not safe on wet roads after 5000 miles.
hale374 Posted February 18, 2009 #12 Posted February 18, 2009 Mine was making that same noise with the Dunlops. Sounds like a truck with oversized tires humming by. I switched out to the Michelin Commanders and now have a smooth and quiet ride.
wild hair 39 Posted February 18, 2009 #13 Posted February 18, 2009 went for a ride the other morn 25 dg,first time i've had a wabble,sence changing front tire after about 50 mls it went away,none sence,must have been the temp
Jethroish Posted February 18, 2009 #14 Posted February 18, 2009 My OEM D404s began to howl around 8 or 9000 miles. Slightly louder in a turn. There was no cupping, but you could feel the wear on the tread.
raceman62race Posted February 18, 2009 #15 Posted February 18, 2009 I have an 08 RSV and at 1800 miles my final drive started to whine but it would stop whining if you pulled the clutch in. I also cupped the OEM tires. I bought my scoot new and it came with Bridgestones. After I got the final drive replaced, I could hear the tire whine but it seemed to go away or get much quieter while leaning in corners. I ended up replacing the tires and I bought a set of Dunlop elite III's. So far, they have performed well but I only have about 3000 miles on them.
CMIKE Posted February 18, 2009 #16 Posted February 18, 2009 I got about 3300 miles on my 07 Midnight...when you lean it off center you can hear the rear tire noise. I do not notice it all the time...just when I hear it...I can do a little zip zap in the lane and confirm that it is tire noise. Cannot wait to get them 404's replaced.
waterbug Posted February 18, 2009 Author #17 Posted February 18, 2009 I cant say that I heard it or not in a corner or a lean as when I first heard it it was mostly starights and stop and turns til home. But what ever it is I hope wrty takes care of it for me.
sportssonny1968 Posted February 19, 2009 #18 Posted February 19, 2009 It's going to be the tires, I put up with the noise for 14,000 miles then decided to buy avon venom tires. Couldn't believe the differance it made.
waterbug Posted February 19, 2009 Author #19 Posted February 19, 2009 I am not saying its not the tires because it does kinda sound like them but I havent heard of any just doing it all at once like this did. I have to remember to call the dealer and have them look at it to make sure for my piece of mind I guess
Squidley Posted February 19, 2009 #20 Posted February 19, 2009 I am not saying its not the tires because it does kinda sound like them but I havent heard of any just doing it all at once like this did. I have to remember to call the dealer and have them look at it to make sure for my piece of mind I guess The tires can many times be something that just all of a sudden you hear or feel. I know when I have had tires (especially the rear) start to cup it makes the bike handle poorly and I feel it in the front end. Let us know how it goes and we'll be here
waterbug Posted February 19, 2009 Author #21 Posted February 19, 2009 I called the dealer today and told them when its nice enough to ride it over I will drop it off to them. I told them what it was doing and he said it could be the tires but he has seen some that the rear end is out of alignment and making it howl like that, but they would be happy to make sure it is alrite and take care of it for me. I will say that everytime I have had a problem they have tried to take care of it and tell my why it is doing what it is.
Mariner Fan Posted February 23, 2009 #22 Posted February 23, 2009 Kevin, I got over 9000 miles on my tires and I don't hear the noise. I'll have you take a ride on my bike to see if you can hear it. Bob
waterbug Posted February 25, 2009 Author #23 Posted February 25, 2009 It was nice when I came home today alittle chilly but I dont let that bother me to much, any way I took the bike and decided to track this noise. I noticed that as I would lean from side to side and it hit the tread on the sides more the noise was louder and I do think the side treads are cupped alittle but not sure if its that or the way the tread is made as its not really bad.and after riding for a few min I did notice that it does sound alot like the tires and I would say I am 90% sure that is what I am hearing. Now I just have to figure out what I want to do with it or about it, I dont have the extra money to change them out at the moment and I dont think it will do anything other than make noise rite? Thanks
fardnarger Posted February 25, 2009 #24 Posted February 25, 2009 My 2005 Venture has 22,678 miles on it, I am on my second set of Dunlop 404s (got 12,000 on first set) never had a problem with noise from them, My Wife's VTX 1300 has 404s on it and have never had problems with them, checking the air pressure weekly helps out on getting a lot of mileage on a set. Also be sure and check dates on the tires when you purchase them some have been laying around warehouses for years.
N3FOL Posted February 25, 2009 #25 Posted February 25, 2009 I 2nd the famous rear end whine of the Venture.
