saddlebum Posted February 15, 2009 #1 Posted February 15, 2009 I was just going through the maint. section and reading all the good info there. Your article on clutch slip was really good but you metioned how it was strange that the the clutch would slip in high gear and not in low gear. This is actually is not strange at all as the higher you go up the gear pattern the more load there is placed on the clutch. In transport trucks drivers will often complain that there clutch is slipping on hill climbs we verify this in the shop by placing the transmission in its highest gear then gently let the clutch out. This will either cause the clutch to slip or stall the engine. If we did this in low gear even a clutch that is starting to slip would tear out the driveline unless it was slipping really bad. One thing we really have to watch is as the engines come with higher horse power the force on the driveline increases. wouldn't want to explain that one to a customer. hope you dont tak take this the wrong way and as always keep up the great work.
Freebird Posted February 15, 2009 #2 Posted February 15, 2009 Actually, that explains it quiet well and even makes sense. Thank you very much.
