Reed Posted February 13, 2009 #1 Posted February 13, 2009 Is there a way to correct the speedometer or just be sadisfided with it whe way it is like the tape deck? Why would you build a speedometer wrong & keep it that way? In 50,000 miles you realy have 54,000 Miles. That should be E-legal. Good if you are selling Bad if your buying! I think Yamaha needs to update just a little.
awsmsrv Posted February 13, 2009 #2 Posted February 13, 2009 Is there a way to correct the speedometer or just be sadisfided with it whe way it is like the tape deck? Why would you build a speedometer wrong & keep it that way? In 50,000 miles you realy have 54,000 Miles. That should be E-legal. Good if you are selling Bad if your buying! I think Yamaha needs to update just a little. If I remember correctly, the odometer is pretty accurate. The speedo is off, so I installed a speedohealer. The SH will, however, affect the odo, too. I'd rather have my speedo accurate. My $.02.
yamatime Posted February 13, 2009 #3 Posted February 13, 2009 stupid question maybe but here goes what is a speedohealer does it work and where can i purchase one ive had the speedo problem now for about six years since i bought my bike new
Missionary Rider Posted February 13, 2009 #4 Posted February 13, 2009 stupid question maybe but here goes what is a speedohealer does it work and where can i purchase one ive had the speedo problem now for about six years since i bought my bike new It's a mini-computer that plugs in-line into the speedo cable. You tell it how much your speedometer is off (probably 9%) and it will correct it. Installation is easy - even I managed it. It's not cheap but it IS worth it to me. Here's the address http://calsportbike.com/sh/
MidlifeVenture Posted February 13, 2009 #5 Posted February 13, 2009 Found it http://www.speedohealer.com/eng/faq.htm
pegscraper Posted February 14, 2009 #6 Posted February 14, 2009 Also these two options. http://www.blackrobotics.com/ http://www.dynamicimports.net/p30.html
