wm.butler Posted February 9, 2009 #1 Posted February 9, 2009 What year did Yamaha start using clear lens on their signal lamps? My 2001 RSV has the amber color & I want to change them out to clear. Thanks for any info you can give. Bill
V7Goose Posted February 9, 2009 #2 Posted February 9, 2009 I think it was 2005, but I am not positive. Should be simple matter to check the part numbers in the on-line parts manuals on Yamahaha web site and see when it changes. Goose
big mike Posted February 9, 2009 #3 Posted February 9, 2009 I just bought them for my 99. The 2007 has the clear lenses so that is the year I ordered them for. They work great. Not sure of the exact year. Hope this helps. Big Mike
wm.butler Posted February 10, 2009 Author #4 Posted February 10, 2009 Thanks for the info. I called two local dealerships and they could not give an answer. Wow!
KiteSquid Posted February 10, 2009 #5 Posted February 10, 2009 Most dealerships sell only one RSV per year...
pegscraper Posted February 12, 2009 #6 Posted February 12, 2009 Here's another fun option. Mirrored turn signal lenses. From ebay, where else?
Riderduke Posted February 12, 2009 #7 Posted February 12, 2009 here is another option for clear lenses. http://clearalternatives.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CA&Category_Code=YAMAHA.1
N3FOL Posted February 12, 2009 #9 Posted February 12, 2009 Riderduke said: here is another option for clear lenses. http://clearalternatives.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CA&Category_Code=YAMAHA.1 ClearAlternative Products are good. I've used them in my Vulcan for clear lens and they are just as great looking as the OEM.
Riderduke Posted February 12, 2009 #10 Posted February 12, 2009 N3FOL said: ClearAlternative Products are good. I've used them in my Vulcan for clear lens and they are just as great looking as the OEM. YUP its what I have on my 04:thumbsup2:
Guest Lightnen Posted February 12, 2009 #11 Posted February 12, 2009 Just to jump in here, I've got an 06 RSV and it has the clear len's. I'm the second owner but I'm sure the first fellow didn't add them for bike was mostly stock..
stroker ace Posted February 12, 2009 #12 Posted February 12, 2009 wm.butler said: What year did Yamaha start using clear lens on their signal lamps? My 2001 RSV has the amber color & I want to change them out to clear. Thanks for any info you can give. Bill You will need two of each part number Yamaha # 1D6-83312-10 # 1D6-83312-20 You will also need four amber bulbs. Hope this helps, lens where less than $20 for all four at my local dealer.
