Danimal Posted February 8, 2009 Share #1 Posted February 8, 2009 Hi folks, So here's what happened, I never winterized my Gen 2 because I had plans to haul down south sometime this winter. Plus I got lazy and hunting and football and blah blah blah. So we finally got a little warmer weather last week and I started it up last week anyway bad gas plus I think I flooded it. So it wouldn't run very well and had smoke pouring out the pipes more on the left side than right. Yesterday I drained the tank and then added sea foam but it still ran poorly. Today I pulled the tank (huge accomplishment for me) and managed to pull the two rear plugs. They were both wet and pretty black, now how the heck do I get to the front ones? There is just a ton of stuff in on top of them. I can't figure it out. I did a search but just didn't happen find what I was looking for. Help me please!!!!!!!!!!!! Danimal Link to comment Share on other sites More sharing options...
kbran Posted February 8, 2009 Share #2 Posted February 8, 2009 (edited) With the tank pulled you have to take the dog bones mounted to the motor and frame off of both sides. 4 allen bolts holding the dog bones on, 2 on top and 2 on bottom. Edited February 8, 2009 by kbran Link to comment Share on other sites More sharing options...
Gold Rush Posted February 8, 2009 Share #3 Posted February 8, 2009 http://labs.trunkful.com/LIT-11616-12-60.pdf This is the link to the downloadable service manual. Will tell you exactly what you want to know... Hope that helps.... Link to comment Share on other sites More sharing options...
Cougar Posted February 8, 2009 Share #4 Posted February 8, 2009 -Remove Driver seat -Remove the bolt for the tank -Remove the two front bolts of the tank -Slide the tank back about 1/3 (can be done without removing the fuel line hose) -Remove Dog Bones -Remove the Front plugs -Good Luck -Jeff Link to comment Share on other sites More sharing options...
Danimal Posted February 8, 2009 Author Share #5 Posted February 8, 2009 OK so first of all thanks for the responses. So I go to the dog bone on the right side and the first three come out fine but the fourth is behind the rear resivoir (spelling?) Can't get my socket with 8mm in there. T handle doesn't give me enough torque to turn it. So do I remove the resevoir? Do I need to have someone hold that up and level? Am I making this too hard? Also do I have the right spark plug tool, it looks like the one in the manual has a hole in it for a screwdriver to break it loose. Mine doesn't I had to put a 11/16 on top and use my breaker bar so I could get at it from an angle from way up there. Moneys no object here as long as it's less than $20 lol. Thanks again Danimal Link to comment Share on other sites More sharing options...
Cougar Posted February 8, 2009 Share #6 Posted February 8, 2009 Yep, forgot.. take the one bolt off the reservoir. just kinda move it aside enough to get that dog bone bolt removed.. nothing will spill. YES get a long socket extension. also a 19mm with a rubber plug inside the socket so you can pull the plug out. what also help me a bit is using a swivel on the extension. This will be ALL easier after you have done it once. about 15 Min's Good Luck Jeff Link to comment Share on other sites More sharing options...
Danimal Posted February 9, 2009 Author Share #7 Posted February 9, 2009 OK thanks Cougar , so your saying to remove the res at the bolt not at the hex nut right? And they make a better spark plug socket for this then? A swivel socket is like a U joint right kinda thingy right? This bunch of people are the best! Not everyone would be willing to help a person the way you folks do. Thanks everyone Venturerider's rock! Danimal Link to comment Share on other sites More sharing options...
Cougar Posted February 9, 2009 Share #8 Posted February 9, 2009 A swivel socket is like a U joint right kinda thingy right? YEP There is is bolt to the right side a believe. just ONE... remove it and push the reservoir over a bit. I am not at the bike right now, but you will see what I mean. Jeff Link to comment Share on other sites More sharing options...
Cougar Posted February 9, 2009 Share #9 Posted February 9, 2009 Just went out and looked.. it is the allen bolt (to the right ) that you will need a 4mm? hex ball end to remove it , then your good to go. also try and get the thin wall 19mm socket for plugs at sears or some place like that get a good one. Link to comment Share on other sites More sharing options...
boominup Posted February 9, 2009 Share #10 Posted February 9, 2009 This is very important! Before removing plugs, take compressed air and blow out the dirt and road grime that collects inside the counterbore on top of the heads. As soon as you remove the plug, that crap could end up inside your cylinder and really make a mess down the road. Just my 2 cents! Brian Link to comment Share on other sites More sharing options...
GG54172 Posted February 9, 2009 Share #11 Posted February 9, 2009 http://labs.trunkful.com/LIT-11616-12-60.pdf This is the link to the downloadable service manual. Will tell you exactly what you want to know... Hope that helps.... Good Lawd thatsa big honkin file. Downloaded, thanks for posting. Link to comment Share on other sites More sharing options...
Danimal Posted February 9, 2009 Author Share #12 Posted February 9, 2009 Alright got it!!!! Unfortunately I didn't blow out those areas before I got going. I don't have access to air so I'm just hoping for the best at this point. I'll go pick up some plugs tomorrow and pray tonight that nothing fell in there! I should have known better but I'm just not mechanically inclined. Thanks again for all the help guys, I'll try to update this when I'm all done. Danimal Link to comment Share on other sites More sharing options...
gibvel Posted February 9, 2009 Share #13 Posted February 9, 2009 They have "canned" air at Wal-Mart in the computer section. This is better than nothing. Link to comment Share on other sites More sharing options...
RedRider Posted February 9, 2009 Share #14 Posted February 9, 2009 Danimal, If you can get down to Fond du Lac, I can help out. If you would like, might even be able to play with my new CarbTune and ColorTune. Haven't started riding yet, although it is supposed to be in the 50s Tuesday. RR Link to comment Share on other sites More sharing options...
Danimal Posted February 9, 2009 Author Share #15 Posted February 9, 2009 Oh wow never even thought about air in a can . I'm definately gonna get some next time. There's a reason my email address is Birdbraindanny I guess. Redrider we got to get together sometime for a ride or something plus I want to learn how to synch those carbs. Ice creams on me! Thanks for all the help guys. Danimal Link to comment Share on other sites More sharing options...
Condor Posted February 9, 2009 Share #16 Posted February 9, 2009 Holy Cr@p!!! And I thought the 1stGens were a PITA to get to.... Link to comment Share on other sites More sharing options...
1BigDog Posted February 9, 2009 Share #17 Posted February 9, 2009 Holy Cr@p!!! And I thought the 1stGens were a PITA Yes, the 1st gens ARE a PITA.....................:duck: Link to comment Share on other sites More sharing options...
Squeeze Posted February 9, 2009 Share #18 Posted February 9, 2009 Yes, the 1st gens ARE a PITA.....................:duck: YES, and we ever will !! !! !! :crackup: :happy34: Link to comment Share on other sites More sharing options...
Condor Posted February 9, 2009 Share #19 Posted February 9, 2009 Yes, the 1st gens ARE a PITA.....................:duck: Yep, and I love my PITA 1stGen!! And your point is??? :rotf: Link to comment Share on other sites More sharing options...
Danimal Posted February 10, 2009 Author Share #20 Posted February 10, 2009 OK finished it today!! Went back together really easy, well except the gas line was still tucked under the tank when I finished . But fixed that pretty quick. This is what happened. I started it and the miss was gone :banana: but it still smoked alot. So the seafoam's been in there for 36 hours and I thought I'd let it idle for awhile to see if anything would happen. It quit smoking while idleing and it would still blow some smoke when I'd rev' er but it seems like less than before. So now I'll just hold off for warmer weather then I'll go out and crank it a little going down the highway. Maybe that will burn out all the garbage in the carbs. Thanks so much to everyone who held my hand thru this process, I COULD NOT have done this you guys. Danimal Link to comment Share on other sites More sharing options...
N3FOL Posted February 10, 2009 Share #21 Posted February 10, 2009 Congrats, Danimal. Glad you were able to replace the plugs. Now I also have a good idea on how to remove those two front plugs. I really thought that all I need is to remove the 'Dog-Bone', but it sounds like I will also have to loosed the tank a little bit. A very important tip for me to remember as well...blow out the dirt before removing the plug wires and spark plug (I tend to forget this step). Regards. Link to comment Share on other sites More sharing options...
Cougar Posted February 10, 2009 Share #22 Posted February 10, 2009 I have always looked down in that hole were the plug goes but have not seen any dirt down there due to the fact that the top of the plug wire after inserted seals the top of the plug hole. It has its own protection dirt cover on it. but I do always look or shine a light down in there. still very clean in there after 9 years now. Jeff Link to comment Share on other sites More sharing options...
