Hope this helps.
Not sure who the author is? I used it to do mine and it worked great! Had it off and put on visor on head light and replaced fairing in 36 minutes, with out a sweat! And still had time to look around in there to see what was going on .
Fairing Removal Instructions
http://www.venturers.org/NextGenTech/2ndGen/images/fairing1.gif
  1. Place the motorcycle securely on the side stand. Protect the front fender with a blanket or other covering.
  2. Remove the chrome front cowling cover by first removing its two mounting screws. Lift up each end of the cover, then push the center of the cover in and carefully lift the entire cover upward. The cover has tabs that insert into slots in the fairing. Do not use excessive force or the tabs can be broken. See Figure 1.
  3. Remove the six screws now exposed along the bottom of the windshield. Lift the windshield upward and remove it. See Figure 2.
  4. Remove the screw at the bottom of the chrome headlight ring and also the six screws which hold on the front of the fairing. Lift the front of the fairing off. If you already have the passing lamp kit installed, you will have to loosen the two screws holding the mounting bar to the lower triple clamp or there won't be enough clearance. This is where a 6 mm ball end allen screw driver comes in real handy.
http://www.venturers.org/NextGenTech/2ndGen/images/fairing2.gif
Following are the steps I took when I split my fairing along with some pictures that may help.
You will need the following tools:
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring1.jpg
Remove the plastic cover from the light bar. It simply snaps on and off:
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring2.jpg
Next, if you have installed the Yamaha Passing Light Kit, then you will also have to loosen the two 6mm bolts that hold the light bar on. You DO NOT need to remove these bolts. Simply loosen them as much as possible without removing them. I usually loosen each side a bit at a time.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring3.jpg
Using a 3mm ballend or allen wrench, remove the four screws from the back side of the fairing on each side as shown below:
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring4.jpg
Now, carefully remove the chrome windshield trim. Lift from each end simultaneously and carefully work towards the center kind of lifting up and back towards the windshield.
When putting the chrome trim back on, start in the middle and then work to the outsides evenly.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring10.jpg
Below are some pictures showing the fragile tabs and where they align. It may help to see what these look like to better understand how to remove the trim.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring11.jpg
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring12.jpg
Now, remove the six windshield screws using a 3mm ballend or allen wrench. These screws also hold on the windshield so be careful. A second person to hold the windshield until all screws are out may be wise. After all six screws have been removed, carefully remove the windshield by gently lifting it straight up.
On Yamaha windshields, most of the mounting holes are slots. The third hole from right (see photo) is an actual hole. By removing the third hole from right last it will help prevent the windshield from sliding out while you are working. This is true for the Yamaha windshields. It is uncertain which if any of the aftermarket windshields are the same.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring6.jpg
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring9.jpg
Remove the screw at the bottom of the headlight trim using a 4mm ballend or allen wrench. This is the last screw holding your fairing front on so be ready to support the fairing until you are ready to lift it out.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring7.jpg
You are now ready to remove the fairing front. Some members have said they can not remove the fairing front without removing the lightbar. I find it comes off quite easily if done right. You must pull out gently, then rotate the fairing front right as you continue to pull it out. I have the Yamaha Light Kit with standard bolts as well as the headlight visor and can get this off with no trouble. Here is a digital video clip of me removing my fairing front:
http://www.venturers.org/Tech_Librar...nts/faring.avi about 2.5mb
On my bike shown in this demonstration, I have removed the fork wind deflectors and do not use them. You may find it necessary to remove these in order to get enough tilt on the lightbar.
Another option of course is to remove the lightbar bolts and gently set the lightbar on top of your blanket covered fender. If you do this, it would be advisable to secure the lightbar with some string to prevent it from sliding off the fender. Be careful not to pinch or stretch the lightbar wiring harness if you use this method.
Finally, you can now get to work on whatever it is you needed to split the fairing for. Below is a picture of the fairing insides.
wol_error.gifClick this bar to view the full image.http://www.venturers.org/Tech_Library/attachments/faring8.jpg
To re-install, simply follow these procedures in reverse. No torque specifications are listed in my shop manual for any of these screws or bolts. Most of these screws are M5 which uses a general torque specification of 35 in. lbs. The screw in the headlight trim is a M6 screw and the general torque specification for that size is 80 in. lbs.
__________________
Idiots out Wondering Around
image.php?u=5596&type=sigpic&dateline=1219585842So many places to go, so little time.
bryan52577 View Public Profile Send a private message to bryan52577 Send email to bryan52577 Find all posts by bryan52577 Add bryan52577 to Your Contacts
post_old.gif 10-19-2008, 08:32 PM
06 RSVM, 86Venture Royal
medal-blue.gif medal-blue.gif medal-blue.gif medal-blue.gif medal-blue.gif medal-blue.gif
Edited by bryan52577
Yes, you do have to split the fairing. The chrome ring on the headlight is held on by tabs bent over the back. When you put the visor on,make sure you get the ring fully seated and the tabs bent back well. I mention this because the visor takes up some room and makes it a little hard to put the ring fully into place. One side of mine slipped off a bit a couple of days later, and I had to split the fairing again to get it right. :080402gudl_prv:
Goose
Do you have to split the fairing to install the headlight Visor?
Yes and If you've never done this before, don't be intimidated ... it's very easy. The only "tricky" part is the chrome piece at the bottom of the windshield. When you put the fairing cover back on, make sure the edges are a snug fit before putting the screws back in. The first time I did mine, I must have had something mis-aligned or maybe a wire had gotten in the way coz one edge of the fairing didn't seem to want to fit right...I pulled it back off and re-positioned it and made sure it was fitting properly before putting the scews in. All-in-all, I've had my fairing split 3 times already since I got the scoot last Nov LOL ... it really is quite easy ... heck, it's so easy, I think I'll go do it again just for fun!
