Mikealiasmike Posted February 4, 2009 Posted February 4, 2009 Whenever I click the forums buttons, either on top or sides the page starts to load then nada. Anybody else having this problem?
mini-muffin Posted February 4, 2009 Posted February 4, 2009 I haven't had any problems, so far. Margaret
Mariner Fan Posted February 4, 2009 Posted February 4, 2009 Mike, I just checked and am having no troubles.
Mikealiasmike Posted February 4, 2009 Author Posted February 4, 2009 Cleared everything, perhaps if I shut down and restart...
SilvrT Posted February 4, 2009 Posted February 4, 2009 You may also have issues with your computer...such as, overloaded temp files or fragmentation of your hard drive or a cluttered registry. Could be any of a number of things. Download a program called Ccleaner (it's free) and run it to clean a lot of this stuff up. Pay attention to what it's going to clean...you may want some things like cookies not removed. Also, do a defragmentation on your drive.
RedRider Posted February 4, 2009 Posted February 4, 2009 You need to lube the drive pins on your computer. Gets rid of all the clicking problems. Always here to help. RR
Mikealiasmike Posted February 4, 2009 Author Posted February 4, 2009 You need to lube the drive pins on your computer. Gets rid of all the clicking problems. Always here to help. RR This did the trick! I used Puterlube, seems the clicking was caused by pins not aligning correctly with the fragmentational forces that were caused by the downdraft of the common effects of buffeting. Might want to look on eBAY for other additives to keep things in order and check on the PSI accordingly. I know pictures are mandatory but seems my cameras broke.... Problem solved. Thanks for the help. God bless. Mike
ibents Posted February 4, 2009 Posted February 4, 2009 Really!!!! its amazing what that Puterlube can do. Ian
Squeeze Posted February 4, 2009 Posted February 4, 2009 ... but seems my cameras broke.... :scratchchin: Might try to cure that with a good Dose of Seafoam, this Stuff does Miracles !!! If not, change Battery Filter, recharge Battery and put new Plugs in .... :happy34:
slick97spirit Posted February 4, 2009 Posted February 4, 2009 could it also be an issue of having a pop up blocker turned on?
BIG TOM Posted February 4, 2009 Posted February 4, 2009 Are we there yet? NO..Now lay back down and we'll wake you when we get there...
