BnkrBill Posted February 1, 2009 Share #1 Posted February 1, 2009 Hello........... I have had my new ride for about 3 days now, posted a question about bogging down and with the help a few of you was able to determine the diaphrams have some holes in them. I have them out. How does a person take the diaphram portion off of the slide? Where the diaphram hooks onto the slide there is what looks like a plastic washer on top and underneath. Does it unscrew? I can get it to twist a little but do not see it coming off very easily. Anybody have an idea how this is done? Thanks Bnkrbill Link to comment Share on other sites More sharing options...
mini-muffin Posted February 1, 2009 Share #2 Posted February 1, 2009 If you buy the assemblies all you have to change is the pilot shaft. Be careful with the plastic flat head screw that inside the slider and all washers under the head of the pin. If you buy aftermarket you have to take them apart but not advisable. Just get the Yamaha ones. Margaret Link to comment Share on other sites More sharing options...
BIG TOM Posted February 1, 2009 Share #3 Posted February 1, 2009 If you buy the assemblies all you have to change is the pilot shaft. Be careful with the plastic flat head screw that inside the slider and all washers under the head of the pin. If you buy aftermarket you have to take them apart but not advisable. Just get the Yamaha ones. Margaret Now why did I think that you were gonna say something about the other kind of diaphram.....my bad...:whistling: Link to comment Share on other sites More sharing options...
Squidley Posted February 1, 2009 Share #4 Posted February 1, 2009 The slide and diaphram are 1 piece and as mentioned by Mini the needle is the removable part. You should take the diaphrams and hold them up to a bright light and look through them for holes. Also I have seen where folks have installed them wrong and the edge was folded over and not working properly. The 1st gen is very picky on the air box and it doesn't take much for it to make it a bit out of whack. Here are a few pics just for grins Link to comment Share on other sites More sharing options...
skydoc_17 Posted February 1, 2009 Share #5 Posted February 1, 2009 I replaced the old diaphragms in my 87'VR with the Ebay diaphragms and it worked well for me. Earl Link to comment Share on other sites More sharing options...
Dano Posted February 1, 2009 Share #6 Posted February 1, 2009 The guy on ebay who sells them has some pics on the listing on how to do it. Caveat Emptor! Dan Link to comment Share on other sites More sharing options...
Freebird Posted February 1, 2009 Share #7 Posted February 1, 2009 I moved this thread here to the First Gen tech talk area. Link to comment Share on other sites More sharing options...
BradT Posted February 2, 2009 Share #8 Posted February 2, 2009 I moved this thread here to the First Gen tech talk area. Nice guy to the new members, tell him you moved the thread to a different section, now when he goes looking for the post in the watering hole, how is gonna see your post about moving it ? BRad Link to comment Share on other sites More sharing options...
Freebird Posted February 2, 2009 Share #9 Posted February 2, 2009 Well, I did leave a re-direct there for a day or two. PLUS...if you are REALLY concerned, you could send him a PM and let him know where it is. Link to comment Share on other sites More sharing options...
Pappa Bear Posted February 3, 2009 Share #10 Posted February 3, 2009 Ok, Who out bid me!!!!!!!! Link to comment Share on other sites More sharing options...
cimmer Posted February 3, 2009 Share #11 Posted February 3, 2009 Not I .. but I do plan on buy a set of these soon off of Ebay.. Let me know when you get yours and I wont bid till after that.. Rick F.. Link to comment Share on other sites More sharing options...
skydoc_17 Posted February 3, 2009 Share #12 Posted February 3, 2009 Marcarl has a really good rite-up about the replacement of the Carb. Diaphragms in the First Gen. Tech. Library. This is for the complete Diaphragm/Slider assemblies not the Ebay Diaphragms only. Here's the link: http://www.venturerider.org/forum/showthread.php?t=19271 Hope this helps, Earl Link to comment Share on other sites More sharing options...
Pappa Bear Posted February 3, 2009 Share #13 Posted February 3, 2009 MarCarl is the man!! Link to comment Share on other sites More sharing options...
Pappa Bear Posted February 3, 2009 Share #14 Posted February 3, 2009 I,ll probably bid on the next set he is showing! I really don't think we need to bid against each other, just communicate and maybe save some$$$$$. Anyone else wanna bid 1st let me know and I'll hold off. Thanks everyone Ron Link to comment Share on other sites More sharing options...
Dano Posted February 3, 2009 Share #15 Posted February 3, 2009 Does he have a buy-it-now price? Seemed to me like it was around 55 bucks plus shipping. Dan Link to comment Share on other sites More sharing options...
lonestarmedic Posted February 4, 2009 Share #16 Posted February 4, 2009 I got in touch with the seller and offered a group type buy or the possibility of contacting the moderators for a spot on our site. Here is what I got back. At this time I cannot get more than 1 set per week. The supply is exceedig the demand. He does not have a buy it now price. So, I suggest that we consider a spot on the forum for "Need this item from a vendor on eBay" I have seen this before on websites. I understand the desire not to drive the price of an item up. I also understand that competition is what makes eBay work. I leave this up to the moderators and how they might want to handle this. I want a set of these for later in the spring. So, I will not be bidding until the end of February. JB Link to comment Share on other sites More sharing options...
hlange Posted February 4, 2009 Share #17 Posted February 4, 2009 I got mine from this vendor about two weeks ago. Took me longer to remove the plastic then to replace the diaphrams. I spent $110.01 to get mine. I had been bidding every week for about 6 weeks and always getting outbid, finally up it to get them. I know that some paid less then I did and that's ok. I paid what I thought they were worth, still a deal since I paid $27.50 each instead of the next best price of $65. Now I know that all four diaphrams on my bike are good. Link to comment Share on other sites More sharing options...
