Eck Posted January 30, 2009 Posted January 30, 2009 (edited) 2nd Gen owners... You may have a slow water leak.... and not even know it. This slow leak can only be seen when the fuel tank has been removed because of its location. The water hose clamp I found leaking is located just above the right hand side engine dog bone. The leak will appear as a white powdery substance on the rubber hose, or on the hose clamp. You may even notice a spot or two on the TOP of the rear valve cover located on the right side front jug. Look carefully because it looks like dirt. I was able to turn the clamp tightening screw about 6 turns before it finally became tight on the hose. NOTE: Do not over tighten the hose clamp where it cuts into the rubber hose. I enclosed this picture to help you see what it will look like. Edited February 5, 2016 by Eck
