Freebird Posted August 25, 2006 Posted August 25, 2006 Gas Tank Removal Removing the gas tank on the RSV or the Royal Star Tour deluxe is very simple. The question does come up here from time to time though so here are some simple step by step instructions. RSTD may vary slightly. http://www.venturerider.org/gastank/tank1%20(Small).jpg Step 1: Remove the cowling around the gas cap. http://www.venturerider.org/gastank/tank2%20(Small).jpg Step 2: Use a pair of pliars to squeeze the tabs to unplug connector from metal tab. http://www.venturerider.org/gastank/tank3%20(Small).jpg Step 3: Unplug the connector. http://www.venturerider.org/gastank/tank4%20(Small).jpg Step 4: Remove the vent hose. http://www.venturerider.org/gastank/tank5%20(Small).jpg Step 5: Remove single bolt on rear tang of tank. http://www.venturerider.org/gastank/tank6%20(Small).jpg Step 6: Remove push pins that hold bib in place. http://www.venturerider.org/gastank/tank7%20(Small).jpg Step 7: Rubber covers just pull off front mounts. Remove covers and then allen head screws. http://www.venturerider.org/gastank/tank8%20(Small).jpg Step 8: Turn fuel petcock to "OFF" position and them remove gas line. http://www.venturerider.org/gastank/tank9%20(Small).jpg Step 9: Simply lift tank off and set it aside. You are done.
