My 83 has a broken connector piece that goes from the rear blake light switch to the brake pedal. The piece seems to be not much more than a wire with a few coils near the pedal end.
The switch will activate the brake light but with no connection to pedal no brake lights.
Anyone have an idea?
Thanks in advance
Steve
What you are missing is the spring that pulls the switch to activate it. You have 2 options: 1-- Buy a new switch assembly, which is the only way Yamaha sells the spring. 2-- Find a spring that is close and make it work.
I had the same problem last fall and asked the local shop owner about it to which he replied "Go to a hardware store and buy a spring and make it work. I spent an hour or better making it work. The first spring I tryed was too weak so had to start over. One thing to remember is that the switch is threaded giving adjustment. Or maybe someone with a parts bike can supply one for you. Good Luck
