Some previous posts seemed to indicate that only "non catalytic" mufflers from older generation RK's will work on the Venture. I have the chance to buy some 2008 RK pipes and the numbers do NOT have
95
95a
98
or 98a
as the last digits.
Any reason why the newer RK catalytic mufflers will not work - without any modification (drilling)???
Thanks
  • 1 year later...
I just purchased a new set of RK slip on's from a 2006 RK. Maybe I am reading too much but most on the site are saying they will not work and need to be drilled out if installing. Yet some say they will work just install them cat and all.
I have a 2004 RSV and really would like a beefier sound.
Please help!
Thanks
Medic 19
Thanks my friend.
What is with all the hype regarding removing the Catalytic converter. Some have even posted that the engine will burn out due to uneven pressures??????
Have you installed a set with the cat in tact?
Thanks again for the reply
Medic 19
