starriders777 Posted January 21, 2009 #1 Posted January 21, 2009 I have looked and haveny seen any threads on this, My 99 rsv low feul light does not come on. Is there a fuse or is the bulb blowin? The light does not come on when i turn on the key like the others do. That brings me to another question... Where is the fuses? I hope there not in the fairing. It bothers me that its not working.
Roadhand Posted January 22, 2009 #2 Posted January 22, 2009 How many miles have you run without seeign the light come on? It most likely will come on around 170 or so. The fuse you are looking for is located on the left side (behind the cover, under the seat) Other fuses are located in front of your right foot inside the cowl. Neather is hard to get to.
Moped Posted January 22, 2009 #3 Posted January 22, 2009 common problem with low fuel lt. not working is bad fuel sending unit. Most of the time the gage portion still works.
