wild hair 39 Posted January 11, 2009 #1 Posted January 11, 2009 looking for wiring diagrams,or where to get them,its an 86 pace arrow 34',chev chassis 454,vin #1gbkp37w4f3339694 all help'will be rewarded,at the local D Q
friesman Posted January 11, 2009 #2 Posted January 11, 2009 I was looking around and some people were saying you could order copies of older Pace Arrow manuals from Fleetwood for 8 bucks, There is also a place to order manuals for the equipment and the chassis. http://www.fleetwoodrv.com/contact/contact_mh.aspx Good luck! Brian
wild hair 39 Posted January 11, 2009 Author #3 Posted January 11, 2009 I was looking around and some people were saying you could order copies of older Pace Arrow manuals from Fleetwood for 8 bucks, There is also a place to order manuals for the equipment and the chassis. http://www.fleetwoodrv.com/contact/contact_mh.aspx Good luck! Brian i'm waiting on them now,so far no responce
Thom Posted January 11, 2009 #5 Posted January 11, 2009 Lowell , you ain't gonna get one , there is no wiring diagrams for rv's , the only thing that is a drawing that says there is a wire going from the battery to the camper not where it is at or what it do's what do you need to know about that 86 p.a. give me a call and i can work you throw it . Thom 386-717-9245
wild hair 39 Posted January 11, 2009 Author #6 Posted January 11, 2009 What are you having problems with? don't realy know,new battary,charged,sume things just don't work,the wiring don't look allthat bed but something is not hook up right,just need a wiring diag,that will make it lot easer thanks lowell
Thom Posted January 11, 2009 #7 Posted January 11, 2009 don't realy know,new battary,charged,sume things just don't work,the wiring don't look allthat bed but something is not hook up right,just need a wiring diag,that will make it lot easer thanks lowell the engine battery only runs the chassis , the house battery runs every thing else , check the bat. disconet sw. it mite be above the camper door , some are on the dash and read mom./ duel . also check the tank mon. panel , the most likely have a house batt. mon. on that panel , if i was a work i would check out the one i have in the shop , it is a 86 or 88 to tell you where the batt. disconet sw. is . what is not working in the rv ? Thom
93 venture Posted January 11, 2009 #8 Posted January 11, 2009 The chassis wiring should be the same as a gm truck or van is wired,the house part is where the wiring is hard to figure out.
wild hair 39 Posted January 12, 2009 Author #9 Posted January 12, 2009 has three battarys,one for,the leveling jacks,two that are hooked to gather,heater blower,and lights work,can't seam to get much else to work,have check all the fuses i can find,maybe i should take a picture of the bat set up,before i had it towed home,most every thing seamed to work man said the motor is locked up,said it was running it on a weekly test,then it just w ouldn't turn over,haven't got to that yet back to the drawing board,guess thit will keep me off the road lowell
Naked Rider Posted January 12, 2009 #10 Posted January 12, 2009 i belong to another fourm its called RV.net it like this place you can learn alot and they are always ready to help. good luck
CrazyHorse Posted January 12, 2009 #11 Posted January 12, 2009 don't realy know,new battary,charged,sume things just don't work,the wiring don't look allthat bed but something is not hook up right,just need a wiring diag,that will make it lot easer thanks lowell What exactly is not wsorking.
Thom Posted January 13, 2009 #12 Posted January 13, 2009 has three battarys,one for,the leveling jacks,two that are hooked to gather,heater blower,and lights work,can't seam to get much else to work,have check all the fuses i can find,maybe i should take a picture of the bat set up,before i had it towed home,most every thing seamed to work man said the motor is locked up,said it was running it on a weekly test,then it just w ouldn't turn over,haven't got to that yet back to the drawing board,guess thit will keep me off the road lowell the 0ne battery runs the motor , jacks and steps . the two batterys hooked together run the furnace , refer , all the inside lites , fart fan in bathroom , water pump , monitor panel , plug in the shore power cord and all of the house 12volt stuff will work off the power converter, the power converter also charges the 2 batterys that are hooked together , there are two fuse panels the one up front is for the truck and the one next to the 120 volt circuitbreakers is for the house . most of the time if you look at the wire comming from the house fuses you will see each wire is a dif. color . ex. open the outside door behind the refer you should see the 12 volt wires going to the refer , the white wire is always the ground ,the colored wire will go strait to the house fuse box look in the fuse box and find out witch fuse that colored wire gos to . the only things that run on a 120 volt are the power converter , a/c , mic. oven and t/v. the refer runs on 120 v. heating elements or lp. gas but the brains runs on 12 v. Thom
wild hair 39 Posted January 13, 2009 Author #13 Posted January 13, 2009 got to find every thing,thank maybe sume body hook all the battary togather,when i get the circ seprated,right now,don't know whats chassis,and whats coach,i will keep plugging away at it will get it going one of these days,TOM I WILL TAKE SUME PICTURES,maybe you can tell me what they are latter lowell:lightbulb:
wild hair 39 Posted January 13, 2009 Author #14 Posted January 13, 2009 i belong to another fourm its called RV.net it like this place you can learn alot and they are always ready to help. good luck i joined or signed up--willtake me a week or two to find and read about this P A stuff
wild hair 39 Posted January 14, 2009 Author #15 Posted January 14, 2009 http://www.wiring-diagram.com/?gclid=CKLr4-z0i5gCFSAUagod5FUnEA would you beleve it i got a p30 chassis wiring diag from this web site also got a coach wiring diag from fleetwood-[free] don't know how good they are yet will find out today or latter :thumbsup2:
wild hair 39 Posted January 14, 2009 Author #16 Posted January 14, 2009 http://www.wiring-diagram.com/?gclid=CKLr4-z0i5gCFSAUagod5FUnEA would you beleve it i got a p30 chassis wiring diag from this web site also got a coach wiring diag from fleetwood-[free] don't know how good they are yet will find out today or latter :thumbsup2: here it is
