jb1016 Posted January 7, 2009 #1 Posted January 7, 2009 Anybody got tips on removing the socket head 10mm bolt at bottom of forks?? I put impact wrench on it and it just spins the rod inside. any way to keep it from spinning?? JB
GeorgeS Posted January 7, 2009 #2 Posted January 7, 2009 See the 1st Gen Maintenance Library for articles. Select " forums" then scrol down to maintenance librarys.
Dragonslayer Posted January 13, 2009 #3 Posted January 13, 2009 jb1016 said: Anybody got tips on removing the socket head 10mm bolt at bottom of forks?? I put impact wrench on it and it just spins the rod inside. any way to keep it from spinning?? JB I used a impact wrench with extenstion and socket and they spun loose without a problem
GaryZ Posted January 30, 2009 #4 Posted January 30, 2009 I had the same problem with my ZX11D Ninja. One of the guys at the local dealer decided to share his secret . . . Take a broom handle and cut the end so that it can be wedged into the spinning part inside the fork. Jam the broom handle and quick-spin the bottom bolt with a 3/8" air impact wrench. Worked for me on two different sets of forks.
