barry-only-n7 Posted January 6, 2009 #1 Posted January 6, 2009 Hi from France ! Can you tell me if the rear frame is the same on the first and second generation because I want to put the 2nd gen saddlebags on my old 1200 venture ! Thanks for all ! barry-only-n7
pegscraper Posted January 6, 2009 #2 Posted January 6, 2009 Sorry, they won't be a direct fit. But with a little work, anything can be done. The impossible just takes a little longer.
Venturous Randy Posted January 6, 2009 #3 Posted January 6, 2009 Just out of curiosity Barry, what years are you calling a 2nd gen? Could you be refering to the 86/93 bags to be put on a 83/85 bike, since you did mention a 1200 bike? RandyA
barry-only-n7 Posted January 6, 2009 Author #4 Posted January 6, 2009 Hi Randya ! It's that ! I want to put 92 saddlebags on a 85 model ! All the rear of a 92 on a rear frame of 85 ! But I don't know if the rear frames are the same ! The rear frame of the 85 (1200 model) and the rear frame of the 92 (1300 venture model !) My problem is only the rear frame !!! Thanks for all ! Bikers Friendships :happy34:! barry-only-n7
rhncue Posted January 7, 2009 #5 Posted January 7, 2009 barry-only-n7 said: Hi Randya ! It's that ! I want to put 92 saddlebags on a 85 model ! All the rear of a 92 on a rear frame of 85 ! But I don't know if the rear frames are the same ! The rear frame of the 85 (1200 model) and the rear frame of the 92 (1300 venture model !) My problem is only the rear frame !!! Thanks for all ! Bikers Friendships :happy34:! barry-only-n7 No, they will not fit directly but can be made to fit. What you need to do is change the 83 - 86 rear sub frame assembly to the newer 86 - 93. Where ever your getting your bags and trunk from you just need to get the whole assembly that has the bags, trunk, crash bars, rear fender and passenger grab bars. Dick
barry-only-n7 Posted January 11, 2009 Author #6 Posted January 11, 2009 Hi rhncue ! Thanks for all ! I'm looking for a rear 2nd gen frame ! Bikers Friendships ! barry-only-n7
bongobobny Posted January 11, 2009 #7 Posted January 11, 2009 Barry, the chrome saddlebag crash bars/mounting frame for the '86 - '92 DOES mount on to the black rear subframe on the '83 - '85 so if you have all of the chrome frame pieces then everything should bolt right up. You will also need the third chrome piece that goes across the back between the left and right saddlebag mounts for stability. You should also install the chrome pasenger grab bars as a convenience as your existing grab bars will not work. The black rear subframe should be the same. You will also have to use the turn signals from the newer saddlebags as the early '83 - '85 turn signals won't fit. I think you werre confusing people here as they normally refer to the '00 - '09 RSV as the 2nd beneration Venture. They refer to the First Generation as the '93 - '92 with the '93 - '85 as the 1st generation Mark (Mk) 1 and the '86 - '92 as the 1st gen Mk 2...
rhncue Posted January 11, 2009 #8 Posted January 11, 2009 bongobobny said: Barry, the chrome saddlebag crash bars/mounting frame for the '86 - '92 DOES mount on to the black rear subframe on the '83 - '85 so if you have all of the chrome frame pieces then everything should bolt right up. You will also need the third chrome piece that goes across the back between the left and right saddlebag mounts for stability. You should also install the chrome pasenger grab bars as a convenience as your existing grab bars will not work. The black rear subframe should be the same. You will also have to use the turn signals from the newer saddlebags as the early '83 - '85 turn signals won't fit. I think you werre confusing people here as they normally refer to the '00 - '09 RSV as the 2nd beneration Venture. They refer to the First Generation as the '93 - '92 with the '93 - '85 as the 1st generation Mark (Mk) 1 and the '86 - '92 as the 1st gen Mk 2... I've never changed mine so You could be right but I don't think so. It's been awhile since I was wanting to change mine over but the information that I received then was that the sub-frame had to be changed as the newer bag rails and trunk mounts were different. I just went and checked the parts schematics and the sub-frames part numbers are different from 83-85 and 86-93. The pictures look different also. Dick
bongobobny Posted January 11, 2009 #9 Posted January 11, 2009 Ahhh!! Forgot about the trunk. The bag hardware bolts right up, but yes the trunk rack is different. I used an '85 so it just bolts on in place of the '84. Actualy, all 3 trunk mounts use the same basic frame with extra stuff added on for each version, i.e. the '85 had extra support welded on, and for the '86 up they added the arms that come down and bolt on to the subframe. I know the saddlebag chrome pieces work as I've already had them bolted up to mine...
barry-only-n7 Posted January 13, 2009 Author #10 Posted January 13, 2009 Hi from France ! Thanks for all ! My bike is like the 84 model in USA but in France we have that in 83 to 88 !!! So I want to put your 85, 86 ....... 1300 model on my old 1200 venture ! Thanks for all ! Bikers Friendships ! barry-only-n7
OldBull Posted January 13, 2009 #11 Posted January 13, 2009 When you figure out exactly what you need I most likely have it off an 86' Venture Royale' - have pic's so you can compare - please though it's hard to send decent sized pic's of any quantity thru this server, send me an email to oldbull@q.com and I'll respond with pic's. Bull
barry-only-n7 Posted January 13, 2009 Author #12 Posted January 13, 2009 Hi oldbull ! I post you my adress ! Thanks for all ! Bikers Friendships ! barry-only-n7
barry-only-n7 Posted January 22, 2009 Author #13 Posted January 22, 2009 Hi from France ! I buy a rear frame of 1300 and it arrives today, it very different ! Now I can search at saddlebags....... Thanks at all ! Take care of yourself ! Bikers Friendships :happy34:! barry-only-n7
